2000 no start - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 30 Old 05-11-2018, 12:43 PM Thread Starter
quikstang2's Avatar
2000 no start
I bought the car Monday for real cheap. 2000 3.8L manual. I'm in the middle of home renovations, so I haven't spent much time on it.
The PO said it had a dead battery and bad fuel sender. He said it had been sitting for 6 months and hadn't started in 3 months. Judging by how rusted and locked up the brakes were/are, I'd say it's been longer.
At his house, it behaved similarly to my previous Miata with a bad ground, which was fixed with new terminal clamps. Some lights and clicks when the key is put in, and not much changes when the key is turned to ACC or ON. When it was turned to START, everything died. (This was tested just with my good battery. His is bad.)
I had a good battery and I put a cable end repair kit on the negative side.
I got more normal behavior from the chimes and lights. The odometer finally displayed actual numbers. I think I heard the fuel pump running when I turned the key to ON. I didn't try the windows or top. When I turned the key to START, I heard a pop (probably relay), everything died, and the lights/chimes went back to the previous condition until I disconnected the battery. No crank, no start. Again, similar to what a previous car did that had a ground problem, so I'm leaning that direction for now.
I quit at that since I had other things to do. I should probably try jumping the starter to see if that's the, or a, problem. I don't have an owner's manual or wiring diagram yet, so I don't know what fuses/relays do what or where the major ground points are. I also need to buy new electrical tools this weekend.
2000 3.8L manual convertible
quikstang2 is offline
post #2 of 30 Old 05-11-2018, 02:48 PM
indy2000's Avatar
You will need to make electrical measurements
Your claim of a bad ground cannot be made by just clicks, and lights
High resistence in any circuit can make loads do funny things
We will need a wiring diagram after you measure voltage drop at the starter during crank
indy2000 is offline
post #3 of 30 Old 05-11-2018, 05:54 PM Thread Starter
quikstang2's Avatar
Yes. I need to take electrical measurements and reference a wiring diagram when I have the ability to do so. I haven't spotted an EVTM or wiring diagram online anywhere yet. Barring someone knowing where I can find one, I'll buy a haggard one off eBay and wait for it to arrive. I agree that measuring the starter is a good place to... start.
I apologize if my wording sounded like I had absolutely diagnosed the problem based on some noises which sound like an unwell R2D2 unit. I tried to imply uncertainty by using the words "similar" and "leaning," as well as making a post asking for advice after a few searches turned up nothing relevant.
post #4 of 30 Old 05-11-2018, 08:01 PM
indy2000's Avatar
try bbb industries for a diagram
once you have a meter
measure for voltage drop during crank on both the signal, pos and neg sides of the starter
indy2000 is offline
post #5 of 30 Old 05-15-2018, 06:49 PM Thread Starter
quikstang2's Avatar
There is an owner's manual and a wiring diagram on the way. The owner's manual comes with some other stuff, some of which is wiring related for the PATS. Might help, might not.
I picked up a cheap meter last weekend, so my goal this week is to make a friend so I can read the meter while they turn the key... and help with some renovations at the house.
Other than that, I got the rear windows to go up and down. The driver side mirror works, passenger is dead. The driver power seat works, passenger is manual. Map lights work.
The front windows cause a huge power draw and wouldn't budge. I'm assuming the car has to be running to drop the top.
I noticed the car has two radios. Looks like the original was a split unit and the CD portion is a slave. Apparently the 2001-2004 got a double din trim panel with some buttons below.
That's about it until I can get a helper.
EDIT:
I decided to yank out the radio and factory CD player. None of the original harness was hacked up, which was good to see. There was a harness plugged into the back of the shift bezel. I'll have to figure out what that is.
I had to hook the battery back up to get the exact mileage to get the title transferred, so I decided to check a few more things. The driver window didn't work, but the passenger front window did, slowly. The lights and high beams all came on. I tried to start it, of course, and as soon as the key turned to start, I heard a loud click and everything was dead. I expected that. No crank, same as before.
post #6 of 30 Old 05-18-2018, 12:38 AM Thread Starter
quikstang2's Avatar
I was going to wait until I could get help taking readings, but conditions have changed. All on their own. The car is self healing. It must be a transformer.
Anyways, we've upgraded from no crank no start to crank no start.
Last night I hooked the battery up for some reason and decided to try starting it. It started to crank, barely, and then the starter made a bunch of rapid clicks. I looked up the possibilities and found: bad starter, low battery, and other inadequate electrical connections.
I checked the battery tonight, it was drained some, so I charged it. Then I made an attempt to start it... it cranked a few times, then rapid clicks. I tried twice more with the same results, but less cranking each time. I couldn't find my jumper box to try and help it out a little. (I'm between houses right now, so it might be at the other one.)
So it's cranking now instead of shutting right off. I don't know that I can get it to start given the PO said the fuel sender is bad. Of course, there's always starter fluid. The tank is probably full of manky fuel anyway.
I'll update if there are changes, measurements or progress.
post #7 of 30 Old 05-18-2018, 01:01 AM
indy2000's Avatar
the battery is not the problem
neither is a jumpstart
indy2000 is offline
post #8 of 30 Old 05-20-2018, 02:13 PM Thread Starter
quikstang2's Avatar
I charged the battery up. I grabbed a jumper battery with an air compressor yesterday at Harbor Freight since I can't find my good jump box.
I hooked them both up and the car cranked harder than Jason Statham in that bad action comedy flick.
I can't explain why the car seemed to improve on its own. Maybe the shop cat found a wire to play with and wiggled it just right.
I am going to assume that the problem is fixed, for now, and move on to fuel. The PO said it had a bad fuel sender. I haven't heard the pump run recently, so I'll probably drop the tank this week and see how that looks, then order parts if needed.
post #9 of 30 Old 05-20-2018, 11:14 PM
indy2000's Avatar
i have never seen a mech/elec problem go away on its own
i have seen misdiagnosing claiming a false positive from faulty testing
if you think its just fixed itself, or the cat did, that is fine
indy2000 is offline
post #10 of 30 Old 05-21-2018, 11:01 AM Thread Starter
quikstang2's Avatar
I am beginning to remember why I stopped visiting Mustang forums back with my first car...
Anyway, a friend stopped by on his way home from work to operate the starter fluid can. We got the car to run. I'll be going through the electrical on the fuel system as I find time this week. If that leads me to dropping the tank, so be it. I'll post the results of that, in case this comes up in someone's search.
At least is starts now. I still have no idea why the relay would shut the car off on start, or why it stopped. If the problem returns, I'll post my findings.
post #11 of 30 Old 05-21-2018, 11:36 AM
indy2000's Avatar
you remember?
were you given advice that was helpful, but required work and knowledge, and you didn't want to put the effort in?
to be consistent, more help from me,,,,,,,,try to stay away from starting fluid
it can self ignite easily, masking a possible not spark
if you think you have a no fuel, can you hear or measure amp draw from the pump?
have you thought of actually measuring the voltage to loads?
as I advised in the first reply? you have the meter, and diagram, no?
indy2000 is offline
post #12 of 30 Old 05-21-2018, 07:45 PM Thread Starter
quikstang2's Avatar
As stated previously: Yes, I have a meter. No, the diagram has not arrived yet.
Also previously stated: I thought I heard the fuel pump run the first time I turned the key at home, but have not heard it since.
I have tested what I have been able to test by myself. When I finally got help, some of the problems that I needed to test were no longer manifesting. I cannot test something that is not currently (pun intended, because you've missed my previous jokes and sarcasm) going wrong. Yes, I have considered testing things, and have done what I could. I have looked up (elsewhere) more fuel specific things to test and said I would be doing that when I have time this week.
Yes, you gave advice that I already said I needed to try when I had the tools/help. Aside from parroting me, you've mostly said that I made claims that I never made and low key called me stupid, lazy and incompetent.
post #13 of 30 Old 05-21-2018, 11:07 PM
indy2000's Avatar
I am going to disregard all your comments, pertaining to your whining
when you get the diagram, post that you have it, then i will show you how to diagnose
i am not going to hold your hand
you want to work on your own car, there are many competent shops out there, you have to learn how it works
indy2000 is offline
post #14 of 30 Old 05-23-2018, 11:06 AM Thread Starter
quikstang2's Avatar
My whining? Dude, you're a trip.
I tested for voltage at the fuel pump fuse, and also at the connector leading to the fuel sender, multiple times. There was 2V at most on two of the pins once. The other times I checked it was less than half a volt, and same story at the fuse. I'll have to sit down and see what each wire goes to and figure out what the readings should be. I can hear the starer relay click when the key is turned to on. (I hear three separate clicks, the other two for other relays I assume.) The wiring diagram arrived, still waiting on the owner's manual. According to the wiring diagram, the fuel pump relay is part of a larger control module and it's under the passenger side fender.
Some of the odd behavior it originally displayed returned for a moment after leaving the key in the on position while I took measurements. No surprise there. I'm going to try and find time to get the battery tested this week, just to make sure it's still good. That will be a good time to dispose of the bad one that was in the car when I bought it.
post #15 of 30 Old 05-23-2018, 05:49 PM
indy2000's Avatar
You got 2 volts at the pump in crank?, run?, what?
indy2000 is offline
post #16 of 30 Old 05-24-2018, 11:23 AM Thread Starter
quikstang2's Avatar
ON position. (Accessory > Off > On > Start) My wing span and number of appendages don't allow me to hold the key in start and simultaneously test a connector behind the gas tank.
I went through all the pages relevant to the fuel pump last night, away from the car. The specific connector (C420) doesn't have diagrams of its own, and the system in general doesn't have testing data in the manual like other circuits have. I'll have to make notes on the wire colors and positions tonight, and find the other relevant connector (C451, I think) to do the same. I keep forgetting the main relay module acronym (CCRM maybe) that's under the fender, but I'll see what wires are bundled in that loom and identify them as well.
Owner's manual came in yesterday, but that's redundant at this point, for this problem.
Life is going to be super hectic through the end of the month with mandatory volunteer work, as if that wasn't killing my time already. Hopefully I can get someone to help after that.
post #17 of 30 Old 05-24-2018, 02:03 PM
indy2000's Avatar
that ain’t an excuse
rig up jumper leads that extend to your meter sitting in view
they make wire
indy2000 is offline
post #18 of 30 Old 05-24-2018, 06:43 PM Thread Starter
quikstang2's Avatar
Or I can wait until someone lends me a hand. It's a far more efficient use of my time, and at least one of the pins should be getting 12V with the key in the ON position, so it looks like I have a problem upstream of that connector anyway.
post #19 of 30 Old 05-24-2018, 06:47 PM
indy2000's Avatar
In crank, pump power only happens with the proper rpm signal to the eec
In run, same thing
You can get tricked
indy2000 is offline
post #20 of 30 Old 05-24-2018, 11:49 PM Thread Starter
quikstang2's Avatar
Alright, for connector 420 (C420), I'll come up with an arbitrary number assignment for the pins:
4321
8765
1 YE/WH - Instrument cluster 19 fuel gauge from thermistor
2 RD/BK - pump motor, Fuel Pump Driver Module 3
3 BN/PK - pump motor, Fuel Pump Driver Module 10
4 BK/OG - from thermistor to ground
5 RD/PK - PCM 62 Fuel Tank Pressure Transducer,
6 GY/RD - to PCM 91 signal return
7 BN/WH - from PCM 90 reference voltage VREF
8 empty/unused
I got partial voltage readings from 1 & 5. The low fuel CEL came on after I unplugged connector 420, so that circuit seems to be working.
1 & 4 run through a thermistor. These are probably the least relevant. 1 had some voltage and if 4 is just going to ground, then it makes sense that it had no reading.
2 & 3 run through the pump, shield is grounded at G400. The diagram conflicts itself for the Fuel Pump Driver Module. The convertible page has it located same as the coupe, "underside of luggage compartment." The coupe page references a convertible page and location that call out the Inertia Fuel Shutoff Switch.
6 & 7 go through a potentiometer, and 5 is also connected. All these are directly to/from the PCM.
I might be able to get the battery tested tomorrow. We'll see how the day goes.
post #21 of 30 Old 05-24-2018, 11:56 PM Thread Starter
quikstang2's Avatar
In run, same thing
You can get tricked
Makes sense. I'd have to be measuring as the key was turned to ON when the pump initially primes, before it shuts off.
I don't hear it run to pressurize the lines, so I'll have to take a measurement at (arbitrarily numbered) pins 2 & 3 to see if the pump is getting voltage at all.
I'm sure I have wire lying around here somewhere. Wouldn't hurt to pick up some more when I get the battery tested and take back a battery clamp I never used, just in case I get some free time and nobody is around to help.
post #22 of 30 Old 05-25-2018, 12:51 AM
indy2000's Avatar
in crank, above 400 rpm, good battery no problem, pump should be on and injectors firing..
you are going to get battery voltage at the pump, ~~10-11volts in a crank
oops you have a PWM pump
you would need a scope to see that
otherwise put a fuel press guage on that
indy2000 is offline
post #23 of 30 Old 05-25-2018, 11:37 AM Thread Starter
quikstang2's Avatar
Good call on measuring the the PWM pump. Not going to happen for sure. I found a brief explanation for anyone reading along.
A fuel pressure gauge is on my list of things to buy.
post #24 of 30 Old 05-25-2018, 01:44 PM
indy2000's Avatar
Do you have a scan tool?
indy2000 is offline
post #25 of 30 Old 05-25-2018, 05:09 PM Thread Starter
quikstang2's Avatar
I do, albeit a cheaper one. It didn't find any codes. I'm not able to check the real time data until the car runs though. I planned on checking everything again after it runs.
post #26 of 30 Old 05-25-2018, 06:13 PM
indy2000's Avatar
Do you have access to cam and crank signal, or rpm signal while cranking?
indy2000 is offline
post #27 of 30 Old 06-04-2018, 01:46 PM Thread Starter
quikstang2's Avatar
Sorry, life got super hectic but it's starting to slow down a little... maybe. The only vehicle related news is the rusty early Bronco was successfully relocated. It's not mine, but I'm hoping to help with the rebuild, whenever that happens.
Back on topic...
I'll see if I can find those sometime this week. Is there anything I should look for in particular with those?
post #28 of 30 Old 06-04-2018, 05:13 PM
indy2000's Avatar
those PIDs on your scan tool?
i am in the bay area, so replying may be slow
indy2000 is offline
post #29 of 30 Old 06-05-2018, 11:08 AM Thread Starter
quikstang2's Avatar
No, for the crank or rpm signals. Any number values that are a normal range?
The PO wasn't lying. The problem was the fuel pump. I still don't know why it was behaving oddly at first. There's a decent amount of corrosion under the back of the car, so there might be some grounds that are fighting some rust. I'll have to check the diagram and go through all those. Maybe the next car I get will be one of those mythical rust free Florida cars. At least it runs now.
I guess the next thing is to clean all the rust off the brakes and bleed the fluid. Hopefully they're salvageable.
post #30 of 30 Old 06-05-2018, 05:08 PM
indy2000's Avatar
400 rpm is usually what will set pump and injectors on
indy2000 is offline
Tags
electrical, electrical issues, ground, no crank, no start
No spark no start.. ZanAridDad GT & SOHC 21 02-11-2013 09:30 PM
2000 GT Mustang No Start PATS ok. 91Saleen GT & SOHC 5 02-05-2013 02:17 PM
2000 GT wont start dwatt GT & SOHC 9 11-03-2012 10:29 PM
Lightning wont start psychoII Lightning/Harley Davidson F-150 18 06-13-2012 09:39 AM
5.0 intermittent cold start problem (long) EL1XR8 5.0/5.8 Engine Tech 4 10-10-2011 01:57 PM
