2001 GT, no crank condition - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 05-09-2018, 07:41 PM Thread Starter
My GT has recently been sitting for a while and I stupidly let it sit too long without starting it. Well I’m paying for it now I’m that it won’t crank. When I connect the battery and go to start it, I get a click and an initial turn of the starter enough to turn the belt an inch or so, then I lose all power. And if I turn the key off and pull it out then go to restart it again I still have to power, no radio, fan anything. If I disconnect the battery and reconnect it I’ll get the radio and fan(a/c) again till I go to start then I’ll get one click and no power.
I don’t have the theft light showing up on the dash during the cranking, and it’s a brand new starter and I’ve had the battery tested, as well as hooked up my truck to it for added juice and I still get the same thing. Both the old and new starter are doing the exact same thing. Any help would be appreciated.
Jwright360 is offline
post #2 of 10 Old 05-09-2018, 08:26 PM
indy2000's Avatar
engine is seized?
indy2000 is offline
post #3 of 10 Old 05-10-2018, 07:01 PM Thread Starter
No it’s not, I freely turned it with a breaker bar no problem, minimal resistance. I turn it about half a turn with the bar and no problem.
post #4 of 10 Old 05-10-2018, 09:33 PM
indy2000's Avatar
what electrical measurements have you made while trying to crank?
indy2000 is offline
post #5 of 10 Old 05-11-2018, 03:28 AM
CrucialProspect's Avatar
Before throwing parts at it, start with a voltage drop test. Like Indy is suggesting, you gotta make sure your getting full voltage to all components. That will rule out all electrical components and connections. A good battery won’t crank a good starter if you got a bad connection or cable.
CrucialProspect is offline
post #6 of 10 Old 05-13-2018, 09:56 AM Thread Starter
I haven’t had a chance to do a voltage drop test yet. I need to get a hold of a multimeter to do that, but that would be running from the positive on the battery to the b terminal on the solenoid correct?
post #7 of 10 Old 05-13-2018, 10:41 AM
indy2000's Avatar
Originally Posted by Jwright360 View Post
I havenít had a chance to do a voltage drop test yet. I need to get a hold of a multimeter to do that, but that would be running from the positive on the battery to the b terminal on the solenoid correct?
Yes, and do do the same for the neg side of the circuit
The starter body is the ground
So one lead on it, and one on batt neg post
Remember, key must be in crank to get proper results
Now that you know where the leads go, what do expect to see, before doing the test?
Knowing what you need to see, before the test is key
indy2000 is offline
post #8 of 10 Old 05-14-2018, 12:03 PM Thread Starter
Now this is an assumption, I’ve got a lot to learn for the electrical side of things. But I’m assuming from the batteries static voltage you would want less then a .5 voltage drop from the batteries normal reading to the reading during the test?
post #9 of 10 Old 05-14-2018, 01:45 PM
indy2000's Avatar
You are measuring for the drop on the conductor, nothing to do with battery voltage
You dont care what the battery voltage is
The neg side might be higher, as it loads with current, but you have a good start there
Now start testing
indy2000 is offline
post #10 of 10 Old 05-14-2018, 02:38 PM Thread Starter
Ok, thank you. I’ll see what I get when I get a hold of a multimeter.
For Sale 2001 Supercharged Mustang GT Convertible 54k Miles msl8er Mustangs For Sale/Wanted, 1999-2004 1 06-02-2015 09:14 PM
For Sale Parting out 2002 Mustang GT bmwm3 Interior Parts 12 03-03-2014 08:07 PM
For Sale 2013 GT 500 Clone aaronlstiles Mustangs For Sale/Wanted 2005-Present 2 12-14-2013 01:24 PM
8 bolt crank?? 2001 GT Jeepman1 GT & SOHC 7 12-11-2010 12:51 PM
