1995 COBRA - tach light - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 02-14-2003, 03:29 PM Thread Starter
i was wondering if anyone knew where the green wire of a tach light goes to on a 1995 svt cobra the diagram they gave me sucked and i cant find any sights. please help me and i dont want to screw it into the dash but i thing any kind of glue or velcro will move around in the hot days of the summer. ANY IDEAS
teebo95 is offline
post #2 of 6 Old 02-14-2003, 07:29 PM
PMS Tuning Forum Moderator
Redsnk95's Avatar
The green wire goes to the negative side of the coil. There are two plugs under the coil. Pull the plug that is closest to the motor, and tap the green wire into that plug. Mine worked that way for years till I bought an ignition box, that is when you will need to move the green wire to the box.
Troy
Troy
1995 Mustang Cobra
347ci 10.52 @ 127.74 NA-Pump Gas (gone)
New Project in the works.
2009 F150 Lariat *tow truck*
Redsnk95 is offline
post #3 of 6 Old 02-14-2003, 10:46 PM Thread Starter
Thanx man I am going to try it out right now and let you know how it goes also should put the red to a accesory or constant power source.
teebo95 is offline
post #4 of 6 Old 02-15-2003, 10:08 AM Thread Starter
well the wire that i had expected to be the right one wasnt i guess. does anyone know if the ground wire is in that harness that comes off of the distributor or off the coil pack.
teebo95 is offline
post #5 of 6 Old 02-15-2003, 06:50 PM
Redsnk95's Avatar
Actually I had it backwards. There are two leads going under the coil. One has two wires in it, it is the plug closest to the radiator. Tap into that lead.
Troy
Troy
1995 Mustang Cobra
Redsnk95 is offline
post #6 of 6 Old 02-15-2003, 07:13 PM Thread Starter
Is the wire yellowish with a stripe on it
teebo95 is offline
For Sale 1995 Cobra Mustang Very Clean!! chrisnuts Mustangs For Sale/Wanted, 1994-1998 20 07-12-2015 08:45 PM
For Sale (IN) 1989 GT Supercharged, 03 Cobra Disc Brakes, Low Miles, Original Paint Shanenindy Mustangs For Sale/Wanted, 1987-1993 32 12-13-2014 07:56 PM
tach light issue 86fox5.0 Electrical & Wiring 0 03-17-2012 05:10 PM
For Sale Ford Racing/Autometer 5" Cobra Jet tach w/shift light BoostCrazy Electronics and Entertainment 2 10-04-2011 10:03 PM
What would you rather shift by - tach or light? Ryan87LX 5.0/5.8 Engine Tech 35 04-11-2002 12:34 PM
