89 multi-function conversion - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 01-08-2018, 01:42 PM Thread Starter
Hi all,
The wiper switch in my 89 GT went bad on me today, wipers are stuck on even with the switch in the off position. If I play with the switch a little and twist it just right then they stop for a bit, but then come back on. New switches are crazy expensive, but I heard there was a conversion that could be done to use the 90 - 93 switches which are much much cheaper. However I can't find the conversion. Can anyone help out and post a link to a write up?
If anyone has a thought that it may not be the switch that would also be helpful. Thank you
Zepyrin is offline
post #2 of 2 Old 01-10-2018, 09:38 AM
indy2000's Avatar
Using the wiring diagrams for each switch
You re pin it
It's just that easy
indy2000 is offline
Multi function wiper switch interchange MustangGTDriver89 Electrical & Wiring 7 05-26-2017 12:39 AM
For Sale Ford Mustang Multi Function Switch, 1990-1993. Phistry810 Interior Parts 0 07-31-2012 12:44 PM
For Sale Ford Mustang Multi Function Switch, 1990-1993 Phistry810 Electronics and Entertainment 0 07-31-2012 12:43 PM
87-93 multi function switch issue? 915.0GT General Mustang Tech 3 01-05-2011 08:58 AM
