05-14 mustang electric fan into foxbody - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 10-07-2017, 10:14 PM Thread Starter
Is this swap possible or has anyone tried it? I searched the old interwebs but didn't come up with anything. I would be using the DCC controller for its operation, if that matters.
Hail the mighty Infantry.
1990 Ford Mustang 5.0 manual ( all options)
Visualboy is offline
post #2 of 6 Old 10-08-2017, 10:29 AM
indy2000's Avatar
does it even fit?
indy2000 is offline
post #3 of 6 Old 10-08-2017, 12:43 PM Thread Starter
Originally Posted by indy2000 View Post
does it even fit?
The dimensions I found for the 05-14 fans appeared to be compatible with the fox radiator e.g. SVE radiator. Of course, some kind of brackets would need to be fabricated but that's ok, I have an SN95 fan on there currently and I had to make brackets so it could fit, so that's no biggie. My big concern is if it would fit with the aforementioned modifications to be adapted to the radiator and if the available fan controllers would be compatible with it as well. I have a DCC controller but I am also unsure it will be compatible.
post #4 of 6 Old 10-08-2017, 01:20 PM
indy2000's Avatar
if it actually fits, that is good.
as for controlling it, that is no biggie
you create the sequence of operation, and design the wiring to accommodate it.
indy2000 is offline
post #5 of 6 Old 10-11-2017, 07:35 PM
Blown88GT's Avatar
Originally Posted by Visualboy View Post
..I have a DCC controller but I am also unsure it will be compatible.
It will work with any e-fan.
1988 GT, 57k mi, Orig Owner
Blown88GT is offline
post #6 of 6 Old 10-12-2017, 12:07 AM Thread Starter
Legit, I will begin experimenting in the coming weeks
For Sale MUSTANG ELECTRIC FAN MACH 1 greenhornet923 Power Adders 21 05-07-2016 01:27 PM
For Sale MUSTANG ELECTRIC FAN MACH 1 greenhornet923 Electronics and Entertainment 2 11-19-2015 01:14 PM
For Sale 99-04 mustang 4.6 radiator with electric fan machine head Miscellaneous Mustang Parts 1 11-13-2013 11:47 PM
For Sale Stock Radiator and electric fan off 2001 Mustang GT machine head Miscellaneous Mustang Parts 0 10-15-2013 11:06 PM
what electric fan off a taurus to run oin my foxbody? dgrobels Superchargers 24 06-02-2012 11:49 PM
