1991 ignition switch wiring - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 09-05-2017, 08:14 PM Thread Starter
I bought a 91 LX that was stolen and wiring trashed. A friend has a V8 donor car that I was able to get the column and ignition switch wiring connector. The wires are close to same color, my question is , the 2 yellow wires-what I have found online is they bridge along the way to the column so there position should not mater.The car starts no matter how there connected to each yellow wire. So does it matter on the yellow wires? the airbag wiring from the donor is not the same as the 91 dash wiring connector, thinking cut the connector from the original column adapt. My plan is after inspection and titling install a tilt 89 column. Thanks
Rockisland65 is offline
post #2 of 2 Old 09-06-2017, 12:59 PM Thread Starter
Yellow ignition switch wires
Any opinion on the location of the two heavy yellow wires. See my prior post. Thanks
Wiring Check needed - Factory alternator wiring harness and battery cut of switch with trunk mount battery Adrenalin 94/95 Tech 0 06-01-2015 09:28 PM
Flex-a-lite wiring to ignition switch??? mendez4047 Electrical & Wiring 4 02-04-2014 08:08 PM
1995 ford mustang gt 5.0l wont start coyotesredneck 5.0/5.8 Engine Tech 1 09-18-2013 09:01 PM
ignition switch question 89GTMustang 5.0/5.8 Engine Tech 5 01-05-2013 07:00 PM
Ignition Switch ? Quick Stallion General Mustang Tech 8 11-16-2010 06:14 PM
