1994 GT Battery wiring suggetions/opinions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 08-23-2017, 06:28 PM Thread Starter
After seeing the condition and how much the starting and charging system had been tampered with I've decided to do all new wiring and relocate the battery to trunk on my 94 GT. I've done some reading up on it and there seems to be several ways to do it, I personally think this is the easiest way but just want to see if this will work ok or if anyone has any suggestions or a better way to go about it. I want to add fuse but not sure exactly where or what size to get. Any help would be appreciated. And sorry for the crappy diagram.
snakebite90 is offline
post #2 of 9 Old 08-23-2017, 07:46 PM
indy2000's Avatar
Alt goes to starter post
Another block ground goes to batt neg
indy2000 is offline
post #3 of 9 Old 08-23-2017, 09:08 PM Thread Starter
Thanks Indy, since it's from alternator to started then to battery can I just put a 150-175amp fuse near positive post? My alt is 130
As far as ground, you don't think the 1/0 from negative post to chassis then from chassis to block is good enough? I'm just asking since most kits only come with 4ft of 4 gauge wire for the ground side, I figured going with the 1/0 would be more than enough.
post #4 of 9 Old 08-23-2017, 09:56 PM
indy2000's Avatar
yes that all sounds fine, fuse as close to battery as possible
indy2000 is offline
post #5 of 9 Old 08-23-2017, 09:57 PM
Saleen414's Avatar
Do you think a 4 gauge cable will support a 130 amp load?
26 X 8.5 Hoosier
Saleen414 is online now
post #6 of 9 Old 08-23-2017, 10:11 PM
indy2000's Avatar
continuous.....no
min needed would be 2AWG rate at 90C
indy2000 is offline
post #7 of 9 Old 08-23-2017, 10:23 PM Thread Starter
Since I have not bought any wire yet would you recommend just doing the 2 gauge instead of the 4?
post #8 of 9 Old 08-23-2017, 10:34 PM
Saleen414's Avatar
Better to have it and not need it, than need it and not have it.
26 X 8.5 Hoosier
post #9 of 9 Old 08-23-2017, 11:17 PM
indy2000's Avatar
yep.
indy2000 is offline
For Sale Parting out 2002 Mustang GT bmwm3 Interior Parts 12 03-03-2014 08:07 PM
For Sale Wiring harnesses 98 GT, 99 GT, 00 GT metalman302 Electronics and Entertainment 4 01-03-2013 12:20 AM
For Sale Mustang GT and Cobra parts! 2kBossGT Modular Engine Parts 14 06-30-2012 04:29 PM
For Sale 1995 Mustang GT wiring harness for ECM, 1995 GT auto ECM, 1995 GT low mile fan cantbuytime Miscellaneous Mustang Parts 0 01-06-2011 10:52 AM
For Sale 1994 Ford Mustang GT 5.0 5spd. Convertible - 66k original miles!! LXFiveO Mustangs For Sale/Wanted, 1994-1998 5 12-18-2010 04:38 PM
