Charging problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 02-02-2003, 10:57 PM Thread Starter
StarrMan's Avatar
Charging problem
OK, so i started the car Sat and it was running kinda rough and the battery gauge was on the low side. It eventually died and I had to jump it. I charged up the battery and it was still reading low on the guage. When hooked to a volt meter at the battery, it put 12.3v with engine off, and 12.1-2v with engine running. I picked up a new alternator and it started and ran fine. I took the car out that night, and later in the evening the dash lights were dimmer and the guage was low again. I pulled the alt and had it tested...it's fine. Anyone experience this same problem?? I'm thinking a bad wiring harness or something.
In Loving Memory, My Son, Anthony Michael Starr 08/14/2007 - 01/21/2008
- 95 GT - Aluminum Heads, Cam, TMoss Cobra intake, S-trim, SCT BA2400, 55's, Longtubes, McLeod bell, TKO-600, 3.55's, etc
- 02 GT (Wife's Toy) - Auto, 4.10's, Lowered, Off Road X, Predator Tuner - [email protected]
StarrMan is offline
post #2 of 3 Old 02-03-2003, 11:16 AM Thread Starter
StarrMan's Avatar
Anyone?? I think it may be the wiring harness....dealer wants $104 for one
StarrMan is offline
post #3 of 3 Old 02-03-2003, 03:16 PM
jaw773's Avatar
Several things may be doing this;
1 - bad ground, check the terminals on the battery, both positive and negative
2 - bad battery, the battery may have been damaged with the bad alternator, if so, the new alt. can get damaged from a bad battery
3 - bad chassis ground, see if this is loose or corroded
4 - before replacing the whole cable, go to NAPA or similar and get the plug assembly that goes into the alternator, it costs around $20 or so, a lot cheaper than a new cable.
5 - bad starter or ignition, if either of these are bad, they can draw too much current and fry out the regulator in the alt or the battery itself
1995 Canary GT drop-top - not much stock left
What's the difference between a wife and a mistress??
Night and day
jaw773 is offline
410 stroker weird overheating problem dbldrew 5.0/5.8 Engine Tech 1 09-28-2012 11:52 AM
Acute driveability problem driving me nuts. Sensors? Vacuum? ...new thread MFE 5.0/5.8 Engine Tech 62 04-27-2011 02:28 PM
Charging problem silver408coupe General Mustang Tech 2 04-16-2011 07:08 AM
charging system and wiring experts help me diagnose this problem demon357 General Mustang Tech 1 01-08-2002 09:09 AM
Fuel Delivery Problem Solved!! Blown46Cobra GT & SOHC 9 12-18-2001 01:44 PM
