1983 digital clock wiring - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 06-16-2017, 06:13 PM Thread Starter
The clock has four wires going to it, brown, blue/white, black, and white/purple.
What wires can I hook up to test it?
There is no display at all. I thought it might have something to do with the radio since they messed up my wiring when they installed an aftermarket radio. I have most of that figured out and a real Ford AM/FM cassette to install once I figure out how the amp figures into the wiring I have left.
There didn't seem to be any common wires between the console and the radio but a bit of a tangle between the message center and the clock. Message center works so I want to test the clock.
How to test would be good to know if I have to replace it with others I find at flea markets and such.
Its a 1983 GLX Convertible that I have from the original owner and has 70,000+miles on it.
Thank you,
Justin
shrlsgrl is offline
post #2 of 5 Old 06-17-2017, 04:41 PM
Trader Feedback: (18)
Here's the wiring diagram for it. Looks like Black is ground, Blue/White is 12v, Brown is illumination/dimmer & I'm not too sure about the white. Hope this helps
93 Alloy Metallic Coupe In Progress
306, Fully Ported Twisted Wedges, Holley Systemax, Comp Cam Pro Mags & Custom Grind, PA Racing Tubular K, MM A Arms, MM Coilovers, Tokico D Specs, Cobra Brakes & Black Bullitts
AllMotorNotch is offline
post #3 of 5 Old 06-18-2017, 08:48 AM Thread Starter
Thank you for this. I tried to test it by supplying 12V+ to any and all combinations of the three tabs that connected to power sources while leaving 12v- to the ground tab. Not a flicker of light to be seen on the display. It's a one owner car that I have known since day one and the clock and other components are cleaner than any replacements I have seen on eBay.
The hunt is on!
Justin
shrlsgrl is offline
post #4 of 5 Old 06-18-2017, 12:16 PM
indy2000's Avatar
try power to all three at the same time
indy2000 is offline
post #5 of 5 Old 06-18-2017, 02:06 PM
ashleyroachclip's Avatar
So the factory deck you have is a digital display ?
You will need 12 + , with key on , 12 + key off for the memory , ground , and 12+ for the lights /dimmer.
Key on can be acc. Or start position .
ashleyroachclip is offline
large intank fuel pump wiring mr_minnis Electrical & Wiring 2 06-13-2016 07:15 PM
1990 5.0 wiring color confusion not THAT dude again General Mustang Tech 10 05-20-2016 08:31 PM
Need help wiring up a 95 Ford engine with a 93 wiring harness Wisconsin_Snake 94/95 Tech 3 10-31-2012 03:39 PM
For Sale MSD Digital 6-Plus with Ford TFI wiring harness CircaV12 Electronics and Entertainment 1 05-23-2011 08:34 PM
