Need info on dash clock pod wiring? (Moved from 94/95 Tech) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 02-02-2003, 01:05 AM Thread Starter
Yung Than's Avatar
Trader Feedback: (22)
Question Need info on dash clock pod wiring? (Moved from 94/95 Tech)
I was wondering where I can info info on the the dash clock pod wiring relating to the wire color code and function? There is a "black" wire, "brown" wire, "white w/purple stripe" wire, "blue w/ red stripe" wire, and some other wire I forgot what color it was. Which is what?
"Officially Unofficial"
Yung Than a.k.a. young Dan
Yung Than is offline
post #2 of 2 Old 02-02-2003, 11:14 PM
TCRIMSONK's Avatar
You may want to try the wireing diagrams in the back of a repair manual.
Or, you could just test them and find out for yourself.
Theres gotta be a ground, a power on (for when the car is on), an always on (to keep it set when you have the car off), and one or two more for the dimming functions. A multimeter should reveal everything.
-Darren
Screaming Yellow 05+ GT 'Vert. 10K miles, and bone stock... for now.
1980 International Scout II - 4" lift, swapping in a 345.
TCRIMSONK is offline
Simple wiring question (Moved from 94/95 Tech) lilemmick Electrical & Wiring 0 01-25-2003 05:53 AM
manual fan switch Moved from 94/95 Tech) Devl95GT Electrical & Wiring 6 09-28-2002 01:17 PM
VORTECH / MSD BTM WIRING (Moved from 94/95 Tech) WWS95GT Electrical & Wiring 2 07-22-2002 04:50 PM
ANybody that has moved battery to Trunk (thread moved from 94/95 Engine Tech) blackgtstang Electrical & Wiring 4 05-07-2002 11:22 AM
Anyone runing turbos? How much PSI are you running? (Thread moved from 94/95 Tech) 2Slow4You Turbochargers 15 04-08-2002 04:31 PM
