1993 GT electrial problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 06-08-2017, 01:30 PM Thread Starter
I have a 93 GT convertible that I just bought. The problem is that it will not start. In fact, will do NOTHING. Battery is 100% fully charged. Checked it with a meter. When I turn the key, there is nothing. no lights, no horn, no start, nothing! When the battery is tested without cables connected, it reads fully charged. When I connect the pos and neg cables, there is a dead short according to the meter. Tried jump starting with a reliable jumper and still get nothing. Any ideas on where to start. Any help or suggestions would be greatly appreaciated.
thanks Al
Al Mc is offline
post #2 of 5 Old 06-09-2017, 01:45 AM
indy2000's Avatar
I have to ask
if the battery is tested good, and you cannot get it to crank
WHY would you try to jump start it?
then we will move on to diag
you will need a wiring diagram for your car in front of you.
indy2000 is offline
post #3 of 5 Old 10-02-2017, 08:15 PM
Following. Same issue here
Riclight is offline
post #4 of 5 Old 10-02-2017, 09:42 PM
indy2000's Avatar
you tried jumping a good battery to?
indy2000 is offline
post #5 of 5 Old 11-06-2017, 11:21 AM
start with your ground cable, then move to the connection on the ecu (make sure you have one and its connected, then look into the key ignition. check all fuses
pabloairmale is offline
For Sale Supercharged 1993 Mustang GT Kbremmer Mustangs For Sale/Wanted, 1987-1993 23 12-24-2015 08:49 PM
For Sale 1992 Mustang GT Converted to a 1993 Mustang Cobra/R Clone. 1993 Mustang Mustangs For Sale/Wanted, 1987-1993 3 01-04-2012 04:26 PM
Misfire problem '96 GT SPLXTREM GT & SOHC 3 12-07-2011 10:54 AM
For Sale 1993 Cobra Seats OPAL Grey CLOTH mach3514v Interior Parts 1 06-23-2011 08:50 PM
