1988 Mustang Headlight Switch / Instrument Cluster Wiring - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-31-2017, 12:29 PM Thread Starter
Hi all! First time back on the forums after being away for 10 years. I'm currently troubleshooting a short on fuse 13. The wire appears to go to the headlight switch, the dimmer switch, somewhere in the instrument cluster for illumination, and to one of the connectors in the vicinity of the radio. I can't locate a wiring diagram or the short. The wire is teal with red line. Any help would be appreciated. All other lights work except for the instrument cluster illumination. Fuse 13 instantly blows as soon as I put a new one in. Really need a full wiring diagram for this particular fuse/wire.
Steps taken so far:
-replaced headlight switch
-replaced dimmer
-replaced melted headlight switch connector
Christopher Cerrone USAF
01 f250 powerstroke 8inch lift 37inch tires, 88 GT restored, 92 lx notch 4cylinder turning drag, 2000 vw jetta - wifes car
fiffer is offline
post #2 of 5 Old 05-31-2017, 08:13 PM
indy2000's Avatar
get a wiring diagram
then using a test light to batt positve
probe the circuit
begin to disconnect connections furthest from power supply to narrow search area
indy2000 is online now
post #3 of 5 Old 05-31-2017, 08:14 PM
indy2000's Avatar
diagrams
1988 ford mustang evtm | eBay
post #4 of 5 Old 06-01-2017, 08:01 AM
black88coupe's Avatar
Trader Feedback: (37)
Originally Posted by indy2000 View Post
EVTM will be your best friend in this situation. I have one for an 88 Mustang. If you would like to text me i will help you out any way that i can.
734-558-0938. Mitch
https://
https://forums.corral.net/forums/5-0-5-8-engine-tech/1869321-who-committed-running-stock-roller-cam.html
black88coupe is offline
post #5 of 5 Old 06-02-2017, 07:45 AM Thread Starter
Thanks for the help. I'll be looking for one at Ford Carlisle today. If I can't find out I'll shoot you a text Mitch.
fiffer is offline
Wiring diagram for back of the headlight switch 5.0 Brian Electrical & Wiring 1 07-16-2014 02:42 AM
For Sale NEW 99-04 ROUSH MUSTANG 120 MPH INSTRUMENT CLUSTER GAUGE PANEL / SPEEDOMETER blh_1952 Interior Parts 1 07-07-2013 08:22 AM
For Sale NEW 99-04 ROUSH MUSTANG 120 MPH INSTRUMENT CLUSTER GAUGE PANEL / SPEEDOMETER blh_1952 V6 Parts 1 07-07-2013 08:18 AM
For Sale 1990-93 Ford Mustang GT/LX Instrument Cluster Zero Miles 140MPH Speedo AREA351 Interior Parts 2 03-13-2012 02:34 PM
1988 Instrument Cluster Lighting Problem d4rkpri35t General Mustang Tech 1 10-13-2011 09:20 PM
