1990 LX reverse light wiring short - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 05-26-2017, 06:44 PM Thread Starter
7upstang215's Avatar
Question 1990 LX reverse light wiring short
Hello All,
When i put my car into reverse (AOD) the fuse blows for the reverse lights, turns signals, and convertible top. I believe I have a short between the transmission switch and the reverse lights since it only blows when reverse is activated. I have my interior completely apart now and hope to get this taken care of over the long weekend as it needs an inspection soon, does anyone know where the reverse light harness runs on the foxbody? This is my first time doing any interior work with this car and the wiring diagrams online aren't terribly helpful with the physical locations.
Thanks!
1990 7up Mustang - Daily
7upstang215 is offline
post #2 of 4 Old 05-27-2017, 10:25 AM
indy2000's Avatar
short must be at or after switch
C106 at rear of trans
C212 behind LH kick panel beside C203
C203 behind LH Kick panel beside C212
C421 light socket connector
I would take a test light to battery positive
start at the trans switch, unplug it verify the short to ground, bulb lights
then unplug light sockets one at a time, to test after each unplug
move your way back to the trans switch unplugging an checking
be very careful when unplugging you DO not want to move the wires much as you might remove the short
this will isolate the section of wire that is short, the wire in question is BK/PK according to my 92 evtm.
from the trans to the light
indy2000 is offline
post #3 of 4 Old 07-14-2017, 07:14 PM Thread Starter
Thanks @indy2000! It ended up being one of the reverse bulbs causing the short. I went ahead and replaced both and no more blown fuses. Thanks again!
post #4 of 4 Old 07-14-2017, 07:44 PM
indy2000's Avatar
you are welcome
indy2000 is offline
Car Rarity? preppypyro General Mustang Tech 8 04-13-2016 01:14 PM
Will a 1990 wiring harness and computer work on a 88 MAF conversion? BlowThisRacing 5.0/5.8 Engine Tech 48 09-20-2014 05:30 PM
Dome light wiring. BradleyRJ Electrical & Wiring 0 09-26-2013 03:28 PM
For Sale 1990 Mustang LX 5.0 Drag Car '90LX Mustangs For Sale/Wanted, 1987-1993 29 08-24-2012 08:45 AM
T5 reverse light and neutral safety switch wiring CFalvey General Mustang Tech 3 01-14-2011 12:40 AM
