2003 Mustang Wiring Pinout - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 02-15-2017, 12:34 AM Thread Starter
Gearbox94's Avatar
Trader Feedback: (37)
Hi guys i'm looking for a pin out for the switches on a 2003 mustang.. Specifically i need the headlight switch, and multi function. i'm looking for a diagram that has a picture of the connector and lists the pinouts and wire colors. I'll post an example of what i'm looking for. I'm hoping someone has a wiring book laying around. I'm sure the wiring is the same from atleast 96 up so if you could attach a few pictures i'd be very grateful. Thanks!
File Type: jpg install-fox-body-mustang-headlight-switch-and-harness_5113048e.jpg (27.0 KB, 8 views)
Crystal White 1995 GT Convertible, TFS Twisted Wedge 170's, Steeda 19 cam, Tmoss ported explorer lower, AMK Racing Products Shorty Headers, Catted X-Pipe to Flow Master 40's, COBRA T-5, Powerdyne Blower @7psi 366RWHP 351RWTQ
Gearbox94 is offline
post #2 of 8 Old 02-16-2017, 03:02 AM
Trader Feedback: (18)
Hope this helps ya out. Let me know if any others you need
93 Alloy Metallic Coupe In Progress
306, Fully Ported Twisted Wedges, Holley Systemax, Comp Cam Pro Mags & Custom Grind, PA Racing Tubular K, MM A Arms, MM Coilovers, Tokico D Specs, Cobra Brakes & Black Bullitts
AllMotorNotch is offline
post #3 of 8 Old 02-16-2017, 04:32 AM Thread Starter
Gearbox94's Avatar
You are the man! Thank you so much! Would you happen to have the wiper/washer switch as well?And If you don't mind me asking where did you find those?
post #4 of 8 Old 02-16-2017, 10:18 AM
No problem. The second connector "C202a" is the only one I see for the wiper part of the switch & then the signal from the switch goes to the GEM module. I have access to most of the Ford wiring manuals back to the mid 90's thru a couple programs we use at the shop so I try to help out when I can because I know alot of times its hard to find a specific diagram you're looking for.
post #5 of 8 Old 02-18-2017, 12:18 AM Thread Starter
Gearbox94's Avatar
Ah so the GEM is what sends the signal to the washer/wiper. I never would have thought about that thanks man! and that's awesome to have access to all those diagrams. I think i might go ahead and order a wiring book for the 03 mustang. I'm dropping a cobra drive train in my 91' so i'm trying to figure out how to rewire all the fox switches to work with the cobra harness.
post #6 of 8 Old 02-23-2017, 08:41 AM Thread Starter
Gearbox94's Avatar
you wouldn't happen to have the pinout for the instrument cluster would you?
post #7 of 8 Old 02-23-2017, 02:15 PM
I gotcha, that should turn out pretty sweet man. I would offer to copy the whole manual for you but it only gives me the option to do page by page so it would take a ton of time.
As for the cluster pinouts, it looks like there's only 2 connectors so I'll attach them
post #8 of 8 Old 03-01-2017, 01:09 PM
Hi...i am a new user here.As per my knowledge the second connector "C202a" is the only one I see for the wiper part of the switch & then the signal from the switch goes to the GEM module. I have access to most of the Ford wiring manuals back to the mid 90's thru a couple programs
LulaNord is offline
Tags
2003, mustang, pinout, switch, wiring
American Traditions, Hot Rods, and Horses; 2013 Mustang review and roadtrip story stevegolf Lounge 0 11-18-2013 09:21 AM
For Sale Misc fox body parts n8secstangg Miscellaneous Mustang Parts 12 02-24-2013 12:29 AM
