1989 blower motor + turn signals out - Ford Mustang Forums : Corral.net Mustang Forum
 2Likes
  • 1 Post By ashleyroachclip
  • 1 Post By indy2000
post #1 of 20 Old 12-29-2016, 02:19 PM Thread Starter
Indo-Canuck-Yankee
Shaker666's Avatar
HVAC blower motor stopped working along with my turn signals the other day. No blown fuses. Not really sure where to start.
'71 Mach 1: totaled - R.I.P.
Shaker666 is offline
post #2 of 20 Old 12-29-2016, 08:24 PM
indy2000's Avatar
with the wiring diagram
indy2000 is offline
post #3 of 20 Old 12-29-2016, 11:33 PM Thread Starter
Indo-Canuck-Yankee
Shaker666's Avatar
Do you have any high quality PDFs of the wiring diagrams? My Haynes manual is getting really ragged and its always been way too small to read easily. Especially in a dimly lit garage.
post #4 of 20 Old 12-30-2016, 12:38 AM
indy2000's Avatar
bbb industries
or wait for me to scan
indy2000 is offline
post #5 of 20 Old 12-31-2016, 08:24 PM Thread Starter
Indo-Canuck-Yankee
Shaker666's Avatar
Ok, so it appears to be intermittent. I've traced it down to 4 dead circuits on the fusebox. Fuse positions 5, 9, 13, and 15 are dead; backprobing them with a DMM yields 0V, fuses are intact.
Fuse #5: Turn lights, backup lights, low fluid module & display module, heated backlite relay
Fuse #9: Heater blower, A/C blower
Fuse #13: Instrument illumination, ISO symbols
Fuse #15: Fog lamps
Looking at some schematics it looks like fuses 5 and 9 are actually powered by the grey/yellow wire from the ignition switch. Backprobing this wire on the fusebox yields no voltage... so would that indicate that the ignition switch could be the problem? I recently replaced the ignition lock cylinder myself and I had to fuss with it in order to get it clocked correctly, maybe I didn't do it right? Everything used to work reliably after the ignition cylinder replacement, but not working well anymore. Sound familiar to anyone?
post #6 of 20 Old 12-31-2016, 09:32 PM
indy2000's Avatar
how are you backprobing the fuses?
indy2000 is offline
post #7 of 20 Old 12-31-2016, 09:49 PM
indy2000's Avatar
5 and 9 are hot in run only
15 is hot only with headlight switch closed
13 is hot only with headlight switch closed
power to ign switch is protected by the fuse link a
if you goofed the switch, you would blow the link
indy2000 is offline
post #8 of 20 Old 01-01-2017, 01:37 PM Thread Starter
Indo-Canuck-Yankee
Shaker666's Avatar
Yeah, I'll have to dig into the ignition switch and check the fuselink. Thanks for replying.
I backprobed by removing the fusebox and literally probing the back of the box where the wires go in. Is it normal to have the hazard flasher mounted on the back of the fusebox, where it's not accessible?
post #9 of 20 Old 01-01-2017, 01:42 PM
indy2000's Avatar
Stop what you are doing, no reason to check ign switch
to check fuses, there is a place to put your probe, on the front of the fuse, all you do is check both sides of the fuse to ground, test light is fastest.
and those fuses must be checked at the correct ign switch position
that is not the signal flasher, that is the hazard
signal is even more difficult, mounted on column
indy2000 is offline
post #10 of 20 Old 01-01-2017, 01:57 PM Thread Starter
Indo-Canuck-Yankee
Shaker666's Avatar
I checked all the fuses before I pulled the box out. And yes, I checked them with the key off and key on since many of the circuits are ignition switch controlled. I know the signal flasher in question is the hazard, the turn signal unit is dangling behind my dash. I should probably zip-tie that back in or something.
After pulling the box out I noticed that a previous owner had attempted to splice into the brown/orange wire going to the heater/AC. This wire is like 12 gauge or something and the crimp and heatshrink wasn't done very well. Copper was exposed and only half the strands were intact. I cut out the offending splice and repaired that using a proper ratcheting crimper and some adhesive heat shrink.
Happy New Year, btw!
post #11 of 20 Old 01-01-2017, 02:03 PM
indy2000's Avatar
some wiring wasn't done properly on that car?
happy new year,
you swimming today?
indy2000 is offline
post #12 of 20 Old 01-01-2017, 02:07 PM Thread Starter
Indo-Canuck-Yankee
Shaker666's Avatar
happy new year,
you swimming today?
I've finally repaired all the "ghetto" in the Ghetto. There has been some bad wiring done to it in the past, wasn't me!
Very wet in Tucson today, but it's nice. Lots of snow down in Ricemound, I hear?
post #13 of 20 Old 01-01-2017, 02:26 PM
ashleyroachclip's Avatar
The ignition switch is known for problems , as they seperate .
Since you said this is intermitten , i would pull the covers off the column , and have a look at the switch.
It is a cheap part to replace , and if original , probably needs it
Shaker666 likes this.
ashleyroachclip is offline
post #14 of 20 Old 01-01-2017, 02:53 PM
indy2000's Avatar
not really,,,,,,small squall came through last night, turned to ice......
get any more fog?
indy2000 is offline
post #15 of 20 Old 01-02-2017, 11:13 AM Thread Starter
Indo-Canuck-Yankee
Shaker666's Avatar
So I pulled the column cover off and inspected the ignition switch. It was coming apart near the front and would explain why some of the circuits weren't working... the switch has been coming apart. BWD makes a Taiwanese copper terminal replacement for $17, Motorcraft available locally for about $37. Motorcraft for this one?
post #16 of 20 Old 01-02-2017, 11:31 AM
indy2000's Avatar
it should be covered at ford under a recall
have a ford dealership, do a OASIS report.
its a RECALL item
indy2000 is offline
post #17 of 20 Old 01-02-2017, 11:44 AM Thread Starter
Indo-Canuck-Yankee
Shaker666's Avatar
its a RECALL item
That's interesting. I did a quick search on the NHTSA website and it won't process my VIN anymore for some reason. I used to be able to lookup TSBs before. You really think it's worth the effort to get Ford to replace it? It's kind of dead in the garage right now, I'd need just the part. Should I pay a visit to the Ford dealer today then?
post #18 of 20 Old 01-02-2017, 12:04 PM
indy2000's Avatar
your choice
I would at least give the dealership your vin to look up.
indy2000 is offline
post #19 of 20 Old 01-02-2017, 01:40 PM Thread Starter
Indo-Canuck-Yankee
Shaker666's Avatar
your choice
Alright, so I contacted the dealership. There's a TSB out for intermittent instrumentation lighting, turn signals, etc. and the repair action is ignition switch replacement. Unfortunately, at least in the US, it is not marked for RECALL action, it's just a TSB. So no dice on that front.
I did find a new Motorcraft SW2474 for $31 locally and installed it (after borrowing my friend's tamper proof torx socket set) and everything is working again.
So thanks guys, for helping diagnose and resolve this problem! The switch had come apart as ashleyroachclip had described.
post #20 of 20 Old 01-02-2017, 01:52 PM
indy2000's Avatar
call ford, hotline, you got a load of bs
that recall if yours not fixed yet, exists forever. regardless of country.......
anyhoo.....ya got it fixed,,,,,,now fix the rest of the wiring.
indy2000 is offline
For Sale Gt500 blower FS FT MightyJo3Young Power Adders 0 11-29-2013 01:38 PM
For Sale Vortech YSI Driverside Blower Kit Adamsy87 Power Adders 8 11-09-2013 03:32 PM
PD Blower vs Centrifugal Blower Jensanity Superchargers 10 02-02-2013 08:41 AM
Blower belt life? Krinkov Superchargers 9 08-03-2011 09:48 PM
all roots blown cars:would you consider a blower upgrade? PURPLEMUSTANG GT & SOHC 2 12-01-2001 09:54 AM
