2001 gt convertible top not working - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 12-11-2016, 02:25 PM Thread Starter
Hey everyojeni have a 01 gt vert and top is notnworking. What are the stepsnto trouble shoot. Also ebrake when pulled light does not come on but light does work according to key on position. Also there is a double din radio dvd player installed as well. Any help is appreciated.
southport2014 is offline
post #2 of 3 Old 12-27-2016, 11:47 AM
keithnra's Avatar
Trader Feedback: (29)
Need help with this also, i know my pump is good
keithnra is offline
post #3 of 3 Old 12-28-2016, 09:19 PM
BrightBlueCobra's Avatar
Need a multimeter or test light. Pop out the switch(top or parking brake mounted) and check for voltage coming into the switch and if it is there actuate the switch and check for output. If there is voltage at the switch but not coming out then probably the switch. If that is OK then you need to check at the pump for voltage. If the pump has voltage then probably the pump. My limited experience with Mustang ragtops not working has been loss of fluid to leakage at the pump or fittings. Hope this helps I am no expert.
BrightBlueCobra is offline
For Sale Parting out 2001 GT convertible twymenburr Miscellaneous Mustang Parts 6 11-23-2013 05:53 PM
For Sale 96 GT Convertible Top turbo96 Exterior Parts 2 08-08-2012 08:09 PM
For Sale 2001 Mustang GT Convertible! New Motor, Top, Clutch, Headers... 1mustang Mustangs For Sale/Wanted, 1999-2004 4 07-16-2012 09:22 AM
For Sale 94-98 convertible gt cobra stayfast top assembly 92droptop Exterior Parts 0 03-23-2011 08:01 PM
For Sale NJ: 2001 Silver Convertible GT 85kmi Mr. Blonde Mustangs For Sale/Wanted, 1999-2004 0 01-17-2011 04:44 PM
