defrost switch into horn button (Moved from 94/95 Tech) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 01-20-2003, 11:59 PM Thread Starter
can i modify my defrost button to act as a horn?
i couldnt get the horn to work with my removable steering wheel..
the defrost button is a open loop/closed loop, it needs to be modified to a momentary closed loop
nate79 is offline
post #2 of 4 Old 01-24-2003, 10:17 PM Thread Starter
for anyone who cares, i did it.
i mounted a momentary switch inside the defrost button.
i finally got rid of all aftermarket switches.
i can do this for other people if needed...
-Nate
nate79 is offline
post #3 of 4 Old 01-25-2003, 02:27 AM
I want you to make my fog light switch honk!!!! and my cruise control for radio volume.. J/K only pullin your leg.
On a serious note: Would you know how to wire the button for the passenger window to go down by pressing it once like the drivers side one. I saw an article somewhere but i can't remember where it was.
Five-O Bullitt is offline
post #4 of 4 Old 01-25-2003, 03:05 AM Thread Starter
i gutted the inside of the case, and mounted a microswitch under the big DEFROST button. a horn is important in los angeles, alot of retards drive cars here.
i think mustangworld.com had an article on how to make both windows go down at once.
nate79 is offline
Suggestions for fuel cut off switch? (Moved From 94/95 Tech) Pizz94GTconv Electrical & Wiring 2 12-07-2002 07:10 PM
Power Window (Moved from 94/95 Tech) 94GTLaserRC The Body Shop 22 11-29-2002 01:55 AM
manual fan switch Moved from 94/95 Tech) Devl95GT Electrical & Wiring 6 09-28-2002 01:17 PM
Anybody with electrical experience (Moved from 94/95 Tech) yellow95 Electrical & Wiring 2 08-02-2002 02:04 AM
No Dash Lights (Moved from 94/95 Tech) quickstang95 Electrical & Wiring 9 07-04-2002 01:33 AM
