2000 Ford Mustang V6 Blinker / Brake Lights / Hazard problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 11-06-2016, 06:08 PM Thread Starter
Hey all,
I have come here out of desperation with a problem with my 2000 Ford Mustang. Last week, I was heading home and the brake lights (not the third brake light, but the main lights) the turn signals, and the hazards all went out. Doing my research I ordered a new Multifunction Switch, and thought I'd have the problem licked easily.
Yesterday and today I went out to install it, and I noticed a couple things. First, one of the connectors on the top of the switch is melted. The wire is still there and the plug looks intact so i figured I'd just plug it in and see what happens. A couple of the wires also came loose from the top plug, but I put them where I determined they should go, and pressed on.
Some part of it must be connected properly because I get wipers and high/low beams. But the symptoms from last week persist: No turn signals, hazards worked once or twice but don't now, and no brake lights. Headlights/taillights/park lights work fine. Third brake light comes on with the brakes.
So I am now in panic mode. I am a do-it-yourselfer but I HATE electrical problems. I've also found repair harnesses for the lower plug, but not the upper plug
Any advice? What should I check next?
unixrevolution is offline
post #2 of 2 Old 11-07-2016, 09:30 AM
indy2000's Avatar
I love electrical, you supply the correct diagram, I will help you test.
indy2000 is offline
For Sale Brand New Jet Performance Ford programmer #15043 j.largent87 Electronics and Entertainment 3 06-27-2011 10:59 PM
