1993 LX 5.0 fuel pump relay - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 01-20-2003, 10:43 PM Thread Starter
I hope that someone can help me. I have only 6.5 volts of power going to my fuel pump and inertia switch. I've been told that my problem may be a fried fuel pump relay switch. I just can't find the dang thing. I have a 93 LX 5.0. Does anyone know where the darn thing is?
Thanks for any help.
dpellegr
dpellegr is offline
post #2 of 13 Old 01-21-2003, 12:10 PM
C. Johnson's Avatar
Since you have a 93 5.0, the relay will be in the engine compartment. It will be just forward of the passenger strut tower. There should be two relays there. One is for the A/C and the other is for the fuel pump.
I have an 89 GT and the fuel pump relay is under the driver's seat. I don't know when the change was made....
Good luck
Casey
-- Casey
1989 GT
2009 Mazda Speed 3
2006 Mazda Speed 6 (wife's car)
C. Johnson is offline
post #3 of 13 Old 01-21-2003, 12:21 PM
ThunderRod's Avatar
under your mass air meter
T-Rod
" This is my post. " John Dunbar-Dances With Wolves
ThunderRod is offline
post #4 of 13 Old 01-21-2003, 01:11 PM Thread Starter
what does it look like? The only things under the maf are 2 black square boxes which have plugs on the ends of them. Are they the relays?
dpellegr is offline
post #5 of 13 Old 01-21-2003, 01:24 PM
Yes, and if you do a search, you'll know which one is which. I know I've explained in detail before which one is the FP relay and which one is the WAC relay, not sure who else has.
FYI, the changeover was made after the '91 model year.
FoxChassis is offline
post #6 of 13 Old 01-21-2003, 01:45 PM Thread Starter
I'm not sure if you have explained it before. I just joined/registered on this board last night. I did find two of them there. Are they the ones with the wires going in one end and a cap on the other with a 5 prong plug?
Sorry and thanks
dpellegr is offline
post #7 of 13 Old 01-21-2003, 01:49 PM
C. Johnson's Avatar
Yes you have found them. Since it is probably too cold for A/C, you could just switch the relays to see if that cures your fuel pump problem. THat is if the A/C WOT relay is still good. THey are both 30a relays if I do remember correctly. If that fixes it, then figure out which one is which.
Casey
-- Casey
1989 GT
2009 Mazda Speed 3
post #8 of 13 Old 01-21-2003, 01:53 PM Thread Starter
Casey - When switching them out do I have to unplug each wire and replug them in or just the cover with the male prongs in them
dpellegr is offline
post #9 of 13 Old 01-21-2003, 02:00 PM
C. Johnson's Avatar
No need to unhook every single wire....There is a connector there believe me. I always unhook it from the engine compartment to get to it easier. THen you should be able to pull the relay apart from the connector. To disconnect it, pull the locking tab on the connector back a bit and give it a good pull. They should come apart. The relay is a small square and most often they are black. The cover you are talking about is the relay itself.
Casey
post #10 of 13 Old 01-21-2003, 02:39 PM Thread Starter
Thanks Casey - got it. It is fried and surprisingly enough, there are two brand new unused ones golted to the fenderwell. someone must have put new ones in and not used the ones attached to the fenderwell. I guess it's like having 2 spares.
dpellegr is offline
post #11 of 13 Old 01-21-2003, 06:18 PM
where is it located on a 1986 GT
American Thunder is offline
post #12 of 13 Old 01-21-2003, 06:27 PM
C. Johnson's Avatar
I have no idea on an 86 model. 87-90 is under the driver's seat. Look under there......
Casey
post #13 of 13 Old 01-21-2003, 07:57 PM
I found it under the drivers seat.
Rico4114
rico4114 is offline
Need some help with 347 (fuel pump, WP, TCC, pulleys) Silverblade 5.0/5.8 Engine Tech 0 04-22-2015 10:02 PM
FOUR CylINDER to V8 1987 car 1993 complete swap 2 fuel pump relays ? rage911 General Mustang Tech 11 10-19-2011 03:14 PM
Want To Trade 1993 white lx 5.0 for black lx 5.0 Orlando blo50 Mustangs For Sale/Wanted, 1987-1993 2 05-24-2011 01:29 PM
For Sale Low 9 Second 1993 LX 5.0 Hatch in Fla. 9Sec93LX Mustangs For Sale/Wanted, 1987-1993 2 02-16-2011 02:03 PM
