2002 GT KILLS BATTERY - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 19 Old 09-07-2016, 02:34 PM Thread Starter
LS1 HTR's Avatar
Trader Feedback: (29)
If it sits more more than a day or two the battery goes stone dead. Odometer has ------- across it when key is off and out of switch and the check engine light is dimly lit. The instrument cluster should not have power when key is off right? Any ideas would be helpful.
File Type: jpg 14218087_1408577635822225_553448157_n.jpg (6.6 KB, 7 views)
LS1 HTR is offline
post #2 of 19 Old 09-07-2016, 05:10 PM
ShiZor9's Avatar
Yes, either you have a bad ignition switch or something has a short around it or the multifunction switch.
ShiZor9 is offline
post #3 of 19 Old 09-07-2016, 05:25 PM Thread Starter
LS1 HTR's Avatar
Also when running it has no check engine light and the odometer reads correctly. Starts great no dragging or anything.
LS1 HTR is offline
post #4 of 19 Old 09-07-2016, 05:31 PM Thread Starter
LS1 HTR's Avatar
ignition switch is cheap enough to replace to see if that clears it up. thanks
LS1 HTR is offline
post #5 of 19 Old 09-10-2016, 11:14 AM
indy2000's Avatar
before throwing parts at it
why dont you find the source of the current draw?
indy2000 is online now
post #6 of 19 Old 09-10-2016, 12:47 PM Thread Starter
LS1 HTR's Avatar
I am going to put my meter on it tomorrow, but I did go ahead and get the switch for 12.00 to have it with me just in case. I was just asking in hopes that someone else might have already fixed a similar problem.
LS1 HTR is offline
post #7 of 19 Old 09-10-2016, 10:10 PM Thread Starter
LS1 HTR's Avatar
Ok so #6 maxifuse under the hood is pulling 0.5 volts with key off. Owners manual says instrument cluster and pcm. Pulled fuse and car cranks but check engine light comes on and dome/trunk lights don't work. Also power locks/keyless remote stops working. The ---- on the odometer and dim check engine light went away. I left the fuse out and I'm gonna see if battery is still charged tomorrow. Any ideas?
LS1 HTR is offline
post #8 of 19 Old 09-10-2016, 10:14 PM Thread Starter
LS1 HTR's Avatar
I might pull the cluster and reinstall fuse to see if draw is still occurring with it unplugged. Every heard of a cluster being shorted causing this?
LS1 HTR is offline
post #9 of 19 Old 09-11-2016, 09:53 AM
indy2000's Avatar
you measred a voltage potential NOT current draw
you need to find the circuits drawing current
post #10 of 19 Old 09-11-2016, 01:58 PM Thread Starter
LS1 HTR's Avatar
i found it this am #39 fuse. the dreaded gem. ugh.
LS1 HTR is offline
post #11 of 19 Old 09-11-2016, 07:12 PM
indy2000's Avatar
how many amps??
post #12 of 19 Old 09-11-2016, 09:49 PM Thread Starter
LS1 HTR's Avatar
My meter crapped out so I had to borrow a friends. Set on 200ma and probing across the top of the mini fuse in the interior fuse box I got 3.9.
LS1 HTR is offline
post #13 of 19 Old 09-12-2016, 09:48 AM
indy2000's Avatar
3.9 milli amps is not a draw to worry about
are you sure its not 3.9 amps??
post #14 of 19 Old 09-12-2016, 08:52 PM
He went in parallel of the fuse, reading is useless.
OP, do you need more help with this? In order to read current you have to be in series with the circuit or use a dc clamp on.
vertvert is offline
post #15 of 19 Old 09-12-2016, 11:23 PM Thread Starter
LS1 HTR's Avatar
I got a gem on the way. Yes I need all the help I can get but I'm handicapped now because my meter crapped out. I'm just gonna install new gem and wait on my meter to get back from getting repaired. Thanks for all the input so far.
LS1 HTR is offline
post #16 of 19 Old 09-13-2016, 12:31 AM
indy2000's Avatar
gem on the way?
how do you know anything is wrong with it?
you pooched your meter's fuse
by not using it correctly??
post #17 of 19 Old 09-13-2016, 09:24 AM Thread Starter
LS1 HTR's Avatar
No I checked the fuse and replaced it just to be sure. It was a older Snap on one. I sent it to be repaired. I have a friend with a mustang salvage yard and got one cheap just to see if it fixes my problem. I will know more in a couple of days.
LS1 HTR is offline
post #18 of 19 Old 09-13-2016, 06:44 PM
indy2000's Avatar
cheap meter from a friend from a salvage yard?
post #19 of 19 Old 09-14-2016, 12:04 AM Thread Starter
LS1 HTR's Avatar
Got a gem cheap to try from a friends salvage yard. I sent meter off to get repaired.
LS1 HTR is offline
For Sale 98 Mustang Gt MAF & 2002 Mustang Gt MAF 98snakehorse Modular Engine Parts 3 06-09-2016 01:43 PM
For Sale 2002 GT Supercharged. USN02GT Mustangs For Sale/Wanted, 1999-2004 0 07-11-2013 04:26 PM
For Sale FS: 2002 GT, built, blown, super clean one owner Chances50 Mustangs For Sale/Wanted, 1999-2004 8 01-10-2012 09:13 AM
For Sale 2002 Mustang Gt Built with Low Miles 02BottledGt Mustangs For Sale/Wanted, 1999-2004 1 10-12-2011 05:40 PM
For Sale 2002 Ford Mustang GT Cammed and Blown 02bangstang Mustangs For Sale/Wanted, 1999-2004 8 09-04-2011 11:59 PM
