1985 SVO wipers won't turn off - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 06-02-2016, 09:17 PM Thread Starter
indysvodave's Avatar
They stay on low even when turned to the delay setting or off.
They do go to high when turned to the high setting.
I've removed the switch and looked for burned contacts and went ahead and blew out the the connections. Also followed the wires down to the control board, and opened it up and nothing looks scorched in there either.
What is the most common reason they'd do this?
I really don't want to just start throwing money at it replacing parts.
I can't even find the control board anywhere, although I've only looked at the usual parts stores.
David
85 SVO for Haulin' A$$
2002 F-150 for Haulin' everything else
indysvodave is offline
post #2 of 4 Old 06-04-2016, 09:15 AM
indy2000's Avatar
maybe the wiring has a short to power that is going to the input of the board.........or the actual switch is sending power.
get in there and start testing for voltage at the switch, and input of the board.
Why would you even consider spending money on parts, without a proper diagnosis?
indy2000 is offline
post #3 of 4 Old 11-30-2016, 12:35 PM Thread Starter
Sorry. Life's gotten in the way and I haven't gotten back to the Stang.
Why buy new parts?
Because I suck at troubleshooting electrical.
I'm colorblind. I've fried numerous multimeters trying to tackle electrical gremlins.
I'd rather spend a little money on a part and swap it out in an hour than waste a whole Saturday diagnosing.
Unfortunately, I've found these wipers switches aren't cheap or easy to come by.
David
post #4 of 4 Old 11-30-2016, 06:55 PM
indy2000's Avatar
then you go and buy on!
indy2000 is offline
For Sale 1985 Mustang GT/SVO - Recaro Interior - 9256 Miles - Updated ad MIKE'SVO Mustangs For Sale/Wanted, 1979-1986 3 05-06-2016 10:07 PM
For Sale SVO powerstop cross drilled front rotors, EBC red stuff pads, SVO calipers, SVO spindles, eibach lowering front lowering springs at8tc Suspension 0 01-03-2016 08:09 PM
For Sale 1985 Mustang GT/SVO Recaro Interior - Maybe What Ford should have built? - 9252 Miles MIKE'SVO Mustangs For Sale/Wanted, 1979-1986 14 12-17-2015 11:31 PM
Anyone thought about an engine swap from the new SVO Mustang into an older SVO? mtrain2000 General Mustang Tech 18 04-03-2014 10:30 PM
Problem w/ windshield wipers turning on/off PurpleBlaze GT & SOHC 2 12-21-2001 07:40 AM
