#8 fuse keeps blowing on 1991 LX - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By fox88
post #1 of 11 Old 05-01-2016, 01:25 PM Thread Starter
So my son notices when he starts his car (91 LX), his #8 fuse is blowing. This has happened twice now, once last week and now about a week later. Any typical things to look for? It looks like the hood light and hatchback light are on #8, as are electric mirrors, vanity light, map light, part of the radio, and dome light. Probably glovebox light too. Would not having the lighter plugged in hurt anything? He took the lighter out a couple weeks ago (no coins fell in, promise)?
thanks for any help-
Alchemist is offline
post #2 of 11 Old 05-01-2016, 03:26 PM
indy2000's Avatar
short to ground or short to power
use a test light on all the loads
batt pos and neg
indy2000 is offline
post #3 of 11 Old 05-01-2016, 03:40 PM Thread Starter
Problem is it intermittent. By short to ground, that would be the same as short to power, right. In other words, it's gotta be 12V + touching ground.
post #4 of 11 Old 05-01-2016, 11:33 PM
indy2000's Avatar
start wiggling wires in heat, vibration, sharp corner area
indy2000 is offline
post #5 of 11 Old 05-02-2016, 08:08 PM Thread Starter
Does the amp go thru fuse #8?
1995 Impala SS 396 LT4 intake/heads with GM/Crane 847 Cam Tri-Y headers T56 4.56 gears 58mm TB RAISS intake Cat delete OBD2 PCM Bryan Herter Programming
1974 F-100 390 HP
1991 Ford Mustang LX, 5.0L, Bone Stock
1996 Buick Roadmaster. LT1. Bone Stock
post #6 of 11 Old 05-02-2016, 09:26 PM
indy2000's Avatar
is it not showing on your wiring diagram?
indy2000 is offline
post #7 of 11 Old 05-02-2016, 09:49 PM Thread Starter
Going off memory I do not think it does. My factory manual is at work unfortunately.
post #8 of 11 Old 05-03-2016, 11:03 AM
fox88's Avatar
Easy test if that's the case, pull all the bulbs and the stereo. Turn key on, see if fuse is still good. Prob. will be at that point. Start putting things back in until fuse blows.
tony91723 likes this.
FTI TW heads/FTI cam/RPMII/A-trim/T5 & 4.10's/QH w/ BE & EA/GUFB
www.carstereooneinc.com
fox88 is offline
post #9 of 11 Old 05-03-2016, 11:27 AM Thread Starter
Thank you sir. So how about the mirrors - just assume it's probably not them? How about the light down inside the lighter/storage console? I can't remember if that bulb is on fuse #8 circuit...
post #10 of 11 Old 05-03-2016, 11:42 AM
fox88's Avatar
Well, the power mirror switch is just in the center console. Pop it out and disconnect it also. Won't hurt anything to try.
What I see often at work with similar problems (on any car) is people are always plugging things in/out of cigarette lighters. These plugs often have ends that unscrew, which is where the fuse is at. They come apart, people don't realize it. Those little metal ends lay in the bottom and shorts the power from the center pin to the ground of the outside and poof.
Just check all the easiest things you can first.
fox88 is offline
post #11 of 11 Old 05-03-2016, 05:29 PM
ACJ
ACJ's Avatar
Coin it the cigarette lighter holder ?
ACJ is offline
For Sale 1991 Ford Mustang LX Coupe Untohim Mustangs For Sale/Wanted, 1987-1993 3 01-24-2014 04:24 AM
For Sale 1991 LX 5.0 5SP PerfRed00GT Mustangs For Sale/Wanted, 1987-1993 8 09-11-2013 12:41 PM
For Sale 1991 Mustang LX - Low Miles, Nicely Built hdwilly Mustangs For Sale/Wanted, 1987-1993 11 08-30-2013 09:45 AM
For Sale 1991 LX Hatch for sale blwn88 Mustangs For Sale/Wanted, 1987-1993 2 03-20-2013 09:37 AM
For Sale Feeler Ad: 1991 LX convertible 5.0 5-speed Shelty Mustangs For Sale/Wanted, 1987-1993 0 08-06-2011 11:04 PM
