96 Mustang GT coil pack signal wire shorted to ground - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 04-27-2016, 07:44 PM Thread Starter
Have a no start issue with my 96 Mustang GT. Found out that if I disconnected the power/signal plug on the drivers side coil pack engine starts obviously running poorly on 4 cylinders. The pink/wht signal wire is showing a dead short to ground which i'm sure is causing the problem. The problem is I cant find where the wire physically goes. I know it connects to the pcm but not sure what route it takes to get there. I can't find a plug diagram with pinouts. Any help would be appreciated.
Thanks,
JR
Dicej is offline
post #2 of 8 Old 04-28-2016, 12:27 AM
indy2000's Avatar
a shorted signal wire will take out 1 coil pack, not both, therefore it should run on 6
look at places with heat and vibration along the harness
indy2000 is offline
post #3 of 8 Old 04-28-2016, 01:55 AM Thread Starter
I meant 4 because only the passenger side coil pack is connected. I'm pretty sure the PCM is bad though. Once I unplug the PCM the short disappears. Plug it back in shorts there again.
Thanks,
JR
Dicej is offline
post #4 of 8 Old 04-28-2016, 09:34 AM
indy2000's Avatar
take the ecm,
reconnect the battery
use a test light to battery positive, and touch both control wires to that pack, does it light?
your diag of unplugging the ground, has NOT shown that it is the problem, there is wire in between that you need to check
indy2000 is offline
post #5 of 8 Old 04-28-2016, 04:19 PM Thread Starter
The signal wire goes straight to the pcm. When I disconnect the plug at the pcm the short is no longer there. A short in the wire before the pcm would still show regardless of the pcm being plugged in or not. This leads me to believe the pcm has an internal short. The other 3 signal wires have no continuity to ground. I would love to be wrong but it seems pretty straightforward.
JR
Dicej is offline
post #6 of 8 Old 04-28-2016, 05:37 PM Thread Starter
Originally Posted by indy2000 View Post
take the ecm,
I tried this and as I expected, the light came on when I touched the pink/wht shorted control wire. Pulled the pcm plug and no light.
JR
Dicej is offline
post #7 of 8 Old 04-28-2016, 06:04 PM Thread Starter
The pink/wht control wire goes to pin 78 at the pcm connector. I confirmed continuity between pin 78 on the pcm plug and the pink/wht wire at the connector on the coil pack. There is no continuity between pin 78 and ground. I'm certain there is no short in the wire. Time to order a PCM.
Thanks,
Jenaro
Dicej is offline
post #8 of 8 Old 04-28-2016, 08:31 PM
indy2000's Avatar
I would not rely on a ohm check./
use a test light,,,,,,,you need current
indy2000 is offline
96 Cobra Tach Signal from coil pack? 95SixStang SVT & DOHC 4 03-10-2015 07:16 PM
4.6 DOHC question. Rfreeman37 SVT & DOHC 313 01-07-2014 10:35 PM
New to the forum 2013 Mustang GT Track Pack TrackPack S-197 Mustang GT (2011-2014) 21 06-23-2013 12:09 AM
For Sale Misc fox body parts n8secstangg Miscellaneous Mustang Parts 12 02-24-2013 12:29 AM
For Sale 1991 Mustang GT Black front clip, Doors & ground affects. 89StrokerStang Exterior Parts 3 07-10-2012 12:48 AM
