Gauge cluster lights out, not the headlight switch ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 01-06-2003, 08:21 PM Thread Starter
scoupe89's Avatar
I had been blowing the fuse for the gauge cluster lights and thought maybe it was the headlight switch.
After buying a new headlight switch, I went to replace the headlight switch and found the bakelite connector burned at the pin for gauge lights, clock and interior lights. After using a dremel tool to remove the burned pin area, the wiring still looks OK.
The headlight switch is good and all lights work except the gauge cluster lights. After disconnecting the clock, I am still popping fuses. There is a relay box behind the driver back seat that pops the fuse whenever the interior lights go on. Has anyone with a vert had this problem? I've isolated the circuit, but am wondering if the relay is bad? Any ideas? Anyone have a wiring diagram?
2013 Ford Explorer XLT
2007 Ford F-150 XLT 5.4 Supercab 4x4
Supercharged 1994 GT 5.0 vert - sold
scoupe89 is offline
For Sale 79-86 Autometer Phantom Gauge Cluster Retrofit jmcintyre88gt Electronics and Entertainment 0 07-05-2015 11:35 AM
Gauge Cluster Indicator Lights Not Working ILBullittAustin GT & SOHC 5 02-18-2015 07:22 PM
funky gauge cluster wiring? FOX561 General Mustang Tech 2 08-23-2013 10:26 AM
swapping gauge cluster - PATS security issue? auto vs manual cluster? paradigm GT & SOHC 4 05-27-2012 06:24 PM
pics and a how to for getting an 03 cobra cluster to work in a 96 cobra 03sm3341 SVT & DOHC 1 05-27-2011 12:50 PM
