Battery Lamp will not go off - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 01-04-2003, 06:15 PM Thread Starter
I was changing my battery and accidently touched the battery cables that connect to the battery to the wrong posts for a split second. After installing the battery, I started the car and the little red battery lamp on my cluster comes on and stays on. I tried disconnecting the battery and reconnecting but it stays on, anybody know how to make this light go off? I have a 1993 Mustang GT Vert 5.0 everything is hooked up right and this car is completely stock and never been missed with.
Scott1966 is offline
post #2 of 2 Old 01-04-2003, 10:30 PM
Most likely you fried the diodes in the alternator. It's possible to find an alternator shop that can put in a new diode bridge for you but you might have to get a new alternator.
Volvo 242 w/-94 Ford 347,TFS Stage III heads,GT40 intake,30#injectors,70mm TB,75mm Pro-M,SVO EFI Extender,Kenne Bell BAP, Tremec, 3.73gears etc.etc.
Flyboy is offline
Critique this problem...battery in the trunk kbscobravert Electrical & Wiring 5 07-19-2015 09:52 AM
need help with MSD 6AL install....(LONG horror story inside). bolt-on-bandito General Mustang Tech 34 02-17-2014 06:59 PM
NHRA and battery relocation TomR Drag Racing 2 08-15-2013 06:20 AM
Third brake light access? scott88 General Mustang Tech 2 06-24-2013 03:36 PM
