1994 Battery relocation - Positive cable to power box - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 01-02-2003, 06:25 PM Thread Starter
I'm in the process of moving my battery to the trunk on my 94.
I will be running 2awg wire from the alternator to the cut off switch. I also will be running 1/0 welding cable from the cutoff switch to the power distribution box. Is this the correct method, or is there a better place to run the 1/0 cable?
Also, should I remove the original alternator (black orange) wire from the alternator to the power box?
I will also be running the 1/0 cable for the grounds (block-chassis) (negative terminal-chassis)
scott
fiveptO is offline
post #2 of 2 Old 01-02-2003, 08:12 PM
Big Jay D's Avatar
That will work fine. Make sure to rum a 4 AWG og bigger wire from the alternator to the 1/0 side of the cut off switch. Its the only way to be NHRA legal.
Big Jay D is offline
Battery Relocation Question 97pacificgreen SVT & DOHC 18 03-01-2014 12:14 PM
For Sale Aluminum Relocation Battery Box... SVTOA Miscellaneous Mustang Parts 4 12-06-2011 10:34 PM
For Sale battery box and battery relocation blowout jdsperformance Electronics and Entertainment 23 01-30-2011 01:03 PM
1994 Battery relocation - need more info 88BlackStng-GT Electrical & Wiring 1 12-25-2002 10:52 AM
