1987 mustang dash lights - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 02-09-2016, 12:25 AM Thread Starter
jschroeder0728@yahoo.com's Avatar
Hey I have an 87 gt my hazzard lights nevery worked so I decided to fix the problem and the wires were all mixed up in the connector got it working. Now my dash lights blink with the hazzard flasher. The dash lights were working before. Also my turn signals stopped working after I did the hazard switch. Any ideas would be greatly appreciated
post #2 of 8 Old 02-09-2016, 09:34 AM
indy2000's Avatar
what did you do, in your attempted fix?
what wiring diagram are you using?
indy2000 is offline
post #3 of 8 Old 02-09-2016, 01:14 PM Thread Starter
I used this one
post #4 of 8 Old 02-10-2016, 09:45 PM
indy2000's Avatar
is that diagram for a '87?
what did you do in trying to fix it?
indy2000 is offline
post #5 of 8 Old 02-11-2016, 09:12 PM
How would the wires get mixed up going into the plug? You did check both of the flashers before you did the wire thing, right?
dagenham66 is offline
post #6 of 8 Old 02-12-2016, 07:27 PM Thread Starter
It's the only diagram I could find some I don't know if it's specifically for an 87 or not. The flashers have never worked, so when I pulled the switch off there were wires on out of the connector so I wired it per the diagram. now the the hazzard works but the dash lights flash with it and the dash lights dont come on when when I turn the headlights on. The worked before so I don't know what the deal is. Also the headlight hi lo beam works on one side then whining I switch flash to pass the other side turns on. Everything worked they way it should before I wired the hazzard switch.
post #7 of 8 Old 02-13-2016, 11:51 AM
Trader Feedback: (212)
Make SURE that the Multifunction switch is for your car!
87-89 OR 90-93 YES, the wrong one will cause this problem. been there & done that.
89 Vert. 5.0 5Sp. Burgandy, Black Top, Black Interior. SOLD
92 GT Vert. 5.0 AOD White, Black Top, Black Interior.
92 Coupe. 4 Banger 5 Speed. White, Black Interior.
93 Coupe. DECIDING Calypso Green, Black Interior.
94 GT Convertible 5.0 5 Sp. Red Black/Gray Interior.
95 GT Coupe 5.0 5 Sp. Red, Black Interior.
Jon Evenoff is offline
post #8 of 8 Old 02-13-2016, 03:27 PM Thread Starter
The multifunction switch is for my year
For Sale 94-04 Mustang misc parts (central AL) white2kgt Miscellaneous Mustang Parts 44 06-02-2015 04:12 PM
EXHAUSTED: One man's 4 month journey through the land of Mustang Exhaust...with video MikeLTDLX S-197 Mustang GT (2011-2014) 53 09-30-2013 08:33 PM
