Where is the tach wire? 1994 1995 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 12-26-2002, 08:42 PM Thread Starter
I'm hooking up my Hud Shift light and I have everything connected except the wire to the tach wire. Where is this located? I need to connect it to the terminal of the tach, which is says in the instructions to the tach output on a cd type ignition or the negative side of the ignition coil if using an HEI or points distributor. Has anyone hooked this up to their sn95. I don't have any type of MSD ignition system. Will I need to get something else to hook up this shift light? Thanks
95looker is offline
post #2 of 4 Old 12-26-2002, 08:44 PM
PMS Tuning Forum Moderator
Redsnk95's Avatar
There are two plugs connected to the coil. I think (been awhile) that the plug closest to the intake is the negative wire(s). Just put the tach lead in with that plug. That's how I had my shift light for a long time till I bought an ignition box.
Troy
Troy
1995 Mustang Cobra
347ci 10.52 @ 127.74 NA-Pump Gas (gone)
New Project in the works.
2009 F150 Lariat *tow truck*
Redsnk95 is offline
post #3 of 4 Old 12-26-2002, 08:53 PM
Look for a tan and green wire....i belive its tan with a green stripe.....just tap in to that wire. It comes off the coil i believe. Its been awhile for me too but i'm pretty sure thats the one you need for a Tach signal. I used it to hook up my 5" Monster Tach.
snowflake is offline
post #4 of 4 Old 12-26-2002, 08:58 PM Thread Starter
I see the tan wire from the coil, I will see if it works. Thanks
95looker is offline
Exercising demons Sledger46 5.0/5.8 Engine Tech 16 10-06-2019 11:27 PM
1994 1995 Mustang T-5 vs. AOD-E Transmission Mid-pipe Hangers BrettNorton General Mustang Tech 0 01-03-2017 12:14 PM
Tach problem which wire where? aussiesmg General Mustang Tech 0 05-24-2012 06:25 PM
SUPERCHARGER ON A STOCK 1994 1995 COBRA IJCOBRA Superchargers 6 05-12-2002 11:23 PM
1994 and 1995 Mustang - any difference at all? Imyourzero 94/95 Tech 17 05-02-2002 01:38 PM
