1992 Dome Light - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 01-27-2016, 10:26 PM Thread Starter
RTW0223's Avatar
1992 Dome Light
Hi all,
It appears my dome light is functioning opposite what it should be. With both doors closed, I can press the 2 light switches and the lights come on. However, open the passenger door and the light does not come on. Pressing the switches doesn't turn them on either. If I have the passenger door closed and the driver door open, no light comes on. If I manually depress the plunger, the dome light illuminates.
I'm confused what's going on here. The hatch light is functioning normally... open a door and the hatch light comes on.
'92 5.0 LX
h/c/i and other goodies
If you want your go-fast parts delivered, don't choose USPS!
RTW0223 is offline
post #2 of 14 Old 01-28-2016, 08:33 PM Thread Starter
RTW0223's Avatar
BUMP
'92 5.0 LX
RTW0223 is offline
post #3 of 14 Old 01-29-2016, 12:21 AM
indy2000's Avatar
there is one dome light in the middle, doors control that
the outer two bulbs are controlled by the switches on it.
so describe better what lights are doing what.
indy2000 is offline
post #4 of 14 Old 01-29-2016, 06:40 AM Thread Starter
RTW0223's Avatar
Here we go:
With both doors closed, I read 12v to the green/ yellow connector on the roof and 0V at the black/blue connector. With the driver door closed and the passenger door open, I read the opposite - 12v at the black/blue connector on the roof and 0V at the green/yellow connector.
With both doors closed and pressing the passenger switch, the passenger light and center light come on. Turning that off and pressing the driver switch turns on the driver light and center light. Pressing both switches only turns on the center light.
With the driver door open and the passenger door open, neither switch turns on a light.
Hope this helps.
Update with more info:
With both doors closed, and with the dome light switches turned off, rolling the panel dim switch to "on" does nothing. It doesn't light up the center light. Turning on either the left or right side dome light switch, and then turning the panel dim roller to the "on" position turns the lights off. The panel switch still turns on the hatch light like normal. With both dome light switches on, turning the panel dim switch to "on" turns off the center light.
'92 5.0 LX
RTW0223 is offline
post #5 of 14 Old 01-29-2016, 06:26 PM
indy2000's Avatar
do you have the wiring diagram to follow along?
indy2000 is offline
post #6 of 14 Old 01-29-2016, 06:28 PM Thread Starter
RTW0223's Avatar
No, I have been searching for the correct one and cannot find it.
'92 5.0 LX
RTW0223 is offline
post #7 of 14 Old 01-29-2016, 06:29 PM
indy2000's Avatar
go to bbb industries and print one up there, and let me know.
if you cannot get one, I can scan and email mine.
indy2000 is offline
post #8 of 14 Old 01-29-2016, 10:19 PM Thread Starter
RTW0223's Avatar
ah, this site is amazing, never knew it existed. I've got the Courtesy Lights Wiring Diagram
'92 5.0 LX
RTW0223 is offline
post #9 of 14 Old 01-30-2016, 10:59 AM
indy2000's Avatar
so you are good?
indy2000 is offline
post #10 of 14 Old 01-31-2016, 07:04 PM Thread Starter
RTW0223's Avatar
so you are good?
still having some trouble bud.
If it wasn't working completely, it would be a different story, but the fact that it's working under certain conditions has be baffled. Any help with the diagnostic work?
I just checked, and with both doors closed and with the rheostat turned on, there is 12V power at the blk/bl cable at the dome light. Also, with the passenger door open, I am reading 12V to both cables. So, would the problem be in the dome light itself?
'92 5.0 LX
RTW0223 is offline
post #11 of 14 Old 01-31-2016, 08:45 PM Thread Starter
RTW0223's Avatar
Well I figured it out. There's suppose to be a 3rd screw at the dome light which acts as the ground screw. Dome light fully works now!
'92 5.0 LX
RTW0223 is offline
post #12 of 14 Old 01-31-2016, 09:48 PM
indy2000's Avatar
good find.
indy2000 is offline
post #13 of 14 Old 01-31-2016, 09:55 PM Thread Starter
RTW0223's Avatar
good find.
Thank you for your help!
'92 5.0 LX
RTW0223 is offline
post #14 of 14 Old 02-01-2016, 01:15 AM
indy2000's Avatar
you are welcome
indy2000 is offline
2015+ Ford Mustang 4th Brake Light! Bright Reverse Light! See Install Video Diode Dynamics Diode Dynamics 13 03-20-2019 11:04 AM
Dome light comes on with low beams fast94gt Electrical & Wiring 2 03-20-2017 11:29 PM
Want To Buy Titanium Map Light 1990 - 1992 Crakavelli Interior Parts 0 08-31-2015 12:02 PM
For Sale Grey 91-93 Fox Coupe 3rd Brake Light & Dome Light KennethRisher Interior Parts 1 12-09-2014 07:59 PM
Electrical issues. Turn signals, radio, dome light ect.. svostyle Electrical & Wiring 3 04-29-2014 08:42 PM
