Turn signal problems (Moved from 94/95 Tech) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 12-23-2002, 10:28 AM Thread Starter
Exclamation Turn signal problems (Moved from 94/95 Tech)
MY turn signals doesnt work and after a minute the turn signals work again. Sometime the hazzard light does the same thing too, or only one light flashes. Happen sometime when i start the car and hit the turn signal or the hazzard light
All the fuses and the bulbs are ok.
Please help.
philmiup is offline
post #2 of 7 Old 12-23-2002, 11:05 AM
Don 95Vert's Avatar
Replace the multifunction switch in the steering column.
95 Lightning - Slow
95 Convertible 357 turbo
10.5/135 @ 3800#
SCT Tuned
Don 95Vert is offline
post #3 of 7 Old 12-23-2002, 11:07 AM
Temp fix - when you turn on your turn signal, pull the lever in towards you a tiny bit, should be enough to pic up contacts, but dont pull it far enough for the high beams to turn on.
MehakGT is offline
post #4 of 7 Old 12-23-2002, 11:34 AM Thread Starter
Even if the wiper work the swtich can be broken??
Anyway I already replace the multifunction switch in the steering column and the problems still exist.
philmiup is offline
post #5 of 7 Old 12-23-2002, 12:20 PM
94CobraPace's Avatar
Might try and replace the flasher under the dash?? Give it a try, it might be getting hot and stop working, then when it cools it starts working again.
Also check all your lights and make sure they work.
2010 Shelby GT500, Kona Blue W silver stripes.
2007 Shelby GT500, Vista Blue with Tungston gray stripes, 1 of 119, Wifes car...
94 Cobra Pace car Convertible # 591
2001 Cobra vert # 2001 SOLD
94CobraPace is offline
post #6 of 7 Old 12-23-2002, 12:52 PM Thread Starter
how can the flasher be hot if the car havent been started for couple of hours??
Will try to replace the flasher??
Is there 2 different flasher one for the turn signal and the other for the hazzard??
where are the flasher located in the car??
philmiup is offline
post #7 of 7 Old 12-23-2002, 02:35 PM
94SVT's Avatar
Have you checked your blinker fluid lately? might be low...
Seriously, I agree with cobrapace check the flasher relay under he dash. turn on your blinkers (when they are working) and crawl under the dash and listen for it.
94SVT is offline
Wierd Turn signal, High Beam problems Juiced408W General Mustang Tech 6 12-21-2010 03:10 PM
S-Trim Discharge Tube (Moved from 94/95 Tech) bnhokie Superchargers 18 10-16-2002 08:20 AM
Electrical problems (Moved from 94/95 Tech) Black94GTvert Electrical & Wiring 11 10-07-2002 10:15 AM
VORTECH / MSD BTM WIRING (Moved from 94/95 Tech) WWS95GT Electrical & Wiring 2 07-22-2002 04:50 PM
315 and no panard bar (Moved from 94/95 Tech) Insley95 Wheels and Tires 8 07-11-2002 10:54 PM
