Custom Project - What Wires Do What - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 11-20-2002, 05:45 PM Thread Starter
I'm installing 3 gauges where the factory cd player was installed. I want to use the wiring harness that originally pluged into the cd player to power, light and ground the gauges. I've found the constant power, ground and illumination wires, but can't find the wire that only gives power when the key is in the on/acc position. can anyone help?
LzrRed94GT is offline
post #2 of 2 Old 11-20-2002, 08:34 PM
nunly94gt's Avatar
Use a volt meter and check them all with the car off. Then do it with the key in the on/Acc position. You will get your answer.
1988 Mustang GT. Got my TFS heads and TFS stage 1 cam installed, now onto everything else.
nunly94gt is offline
