headlights on 1988 gt - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 11-13-2002, 04:05 PM Thread Starter
Coilz347's Avatar
i just picked up an 88 gt from a friend of mine but the entire car was just a shell. Its just about back together and im hopeing to have it on the road this weekend. But im having a problem with the headlights.
The headlights only come on when i turn the turnsignal lever all the way back towards the driver.(flashing high beam)
all other lights work tail lights, singnals, corner lights etc.
ive checked all my fuses, and ive replaced the headlights with new bulbs still nothing, is there a ground problem
thanks for your time Greg
Coilz347 is offline
post #2 of 3 Old 11-13-2002, 05:19 PM
check headlight switch for melted or corroted wires other then that there is a ground up front by the headlights I believe so check there too. switch alone could be bad.
94conv is offline
post #3 of 3 Old 11-13-2002, 06:36 PM
I had the same problem and it was the turn signal stalk. It seems that ALL of the power for the headlights (high and low) run thru the stalk. When the contacts wear out, no headlights. I could wiggle my stalk and sometimes the lights would come on and stay on, but it got worse and worse. I would bet money its the stalk. I think mine was about $80 5 years ago.
Force Fed 23 is offline
For Sale 02 (99-04) gt headlights for sale TRUE OEM luke1333 Exterior Parts 21 06-06-2012 01:11 PM
For Sale OEM 800 Mile !! 1988 Gt Roller Shortblock red93notch Windsor Engine Parts 13 03-13-2012 07:49 AM
For Sale 1988 GT Convertible Partout ftgt101 Miscellaneous Mustang Parts 1 07-05-2011 05:35 PM
