OEM Fan question for SN95 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 11-12-2002, 02:50 PM Thread Starter
I was wondering if there was some sort of tech article on how to splice into the stock fan and make it so that I can turn it on with a switch, even when the car is off. Also when the switch is off, it will go back to it's factory settings turning on with the AC or when it gets hot. Thanks in advance
chris95svt is offline
post #2 of 8 Old 11-12-2002, 05:12 PM
ls1huntr's Avatar
me too
ls1huntr is offline
post #3 of 8 Old 11-12-2002, 05:37 PM
mayo302's Avatar
I know that there is one, I believe there is a thread on how to do it with the '97s where you splice into a ground wire in the passenger kick panel and apparently this is a simple solution to complete the circuit.. I have not seen it lately though, and I want to do it! Anyone know of information on this item?
Matt Freeman '95 GT T-5, ... email mayo302 (at) gmail.com
mayo302 is offline
post #4 of 8 Old 11-12-2002, 06:05 PM
PoonRacing's Avatar
PoonRacing is offline
post #5 of 8 Old 11-13-2002, 09:31 AM Thread Starter
Thats exactly what I was looking for, thanks poon!
post #6 of 8 Old 11-23-2002, 09:06 AM
hot cobra
I just installed a 9lb powerdyne on my 95 Cobra. It hs been running hot, even after replacing water pump, thermostat, and cleaning/flushing factory radiator. I am using a 60-40 water-antifreeze mix with 1 1/2 pints of redline water wetter. It runs in the o-r area of the temp. gauge while running 35mph and up, but appraches the right (l area) side of the gauge at idle. Timing is 8-9 degrees. No chip installed. I have ordered a diablo with a lower fan temperature setting for turning fan on. Has anyone installed a manual fan switch like the one described where the fan wire from EEC is tapped into and a switch installed? Which wire, etc? Thanks for anyone's help. By the way, the powerdyne has awesome power, is very quiet, and cool enough to allow you to rest your hand on it after use. Butch.
butch is offline
post #7 of 8 Old 11-23-2002, 09:24 AM
CHECK THE LINK OUT 2 POSTS ABOVE, STEP BY STEP HOW TO DO IT. I THINK YOUR PROB IS YOUR RADIATOR (GET A BIGGER ALUM 1) I HAVE DONE THE FAN SWITCH AND IT WORKS GREAT, MINE ACTUALLY STOPPED COMING ON BY ITSELF, AND I DONT KNOW WHY OR HOW TO FIX IT SO, THATS MY FIX.
95gt/98cobra clone is offline
post #8 of 8 Old 11-24-2002, 08:06 AM
what kind of fan switch did you use and where did the new sensor tap in?
butch is offline
