Best way to lengthen Oxygen sensor wires (Moved From 94/95 Tech) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 11-12-2002, 04:02 AM Thread Starter
Rusman's Avatar
I installed longtubes and need to figure out the best way to lengthen the O2 sensor wires. I got the longest ones I could find at 12", but it's not enough. On the pass side, I could probably remove it from the harness and that would give me enough slack. The driver side is lacking several inches though. Is there enough slack that I can undo the loom, remove it, retape the loom and be good? I'd rather do it this way than cutting and splicing or adding in extenders.
Gone, but not forgotten:
1995 Cobra #3752/4005
Red/Black Leather
Rusman is offline
post #2 of 9 Old 11-12-2002, 06:57 AM
Why not just use the extenders? When my long tubes went in we couldnt find enough slack in either side to reach.
Calvin_1976 is offline
post #3 of 9 Old 11-12-2002, 08:03 AM
My driver's side O2 sensor does reach without any help. It was the passenger side that did not. Do try to pull the wire from the rest of the harnessed wires and just make sure it doesn't rest against the exhaust pipes. I zip tied mine to the frame just outside the collector on that side, but it does reach.
94GTVert is offline
post #4 of 9 Old 11-12-2002, 11:18 PM
86style's Avatar
dont cut and splice the wires..bad idea. odds are you will mess up the signal to the computer.
use the extenders. you might have to unwrap a bit from the loom.
04 Torch Red Cobra Whipple @ 16psi
JDM tuned 587 h.p. / 520 lb/ft
86style is offline
post #5 of 9 Old 11-12-2002, 11:30 PM
Anaconda's Avatar
I bought O2 sensor extenders from Brothers Performance for like $40. They were well worth it.
Anaconda is offline
post #6 of 9 Old 11-12-2002, 11:34 PM
a97ace's Avatar
Rus
Go to Oreiley's and get you some 16"ers. This is what I got when my LT's went in. You are still going to have to pull some of the wire out of the loom like 94GTVert said. Then just zip tie it all togeather and put some new loom over it. If you can't get the longer O2's, e-mail me and I will get my people to call your people with the right part #'s.
Later
Brian
[email protected]
1995 GT coupe/ (converting from 306ci to 347ci) 70tb,75 MAF........ you know the rest of the story.
2005 Mitsubishi Lancer Evolution (4 doors, 3 diamonds, 2 litres, 1 turbo = 380 awhp)
1989 GT (Building another stroker)
a97ace is offline
post #7 of 9 Old 11-13-2002, 01:19 AM Thread Starter
Rusman's Avatar
Oreilley's only had 12"ers, so Iused that. It works on the passenger side, but is tight. The drivers I spliced some in. Maybe next year when I replace them I'll get the 16" ones.
Thanks.
Red/Black Leather
Rusman is offline
post #8 of 9 Old 11-16-2002, 09:49 PM
Sinful's Avatar
Trader Feedback: (35)
do they have a web site?
link?
thanks
Sinful is offline
post #9 of 9 Old 11-16-2002, 11:13 PM
You can just undo it from the harness, there's enough length there.
65 Fastback - Old School Again
87 McLaren - Topless
98 Ranger 5.0 - Daily Driver
87 Coupe - Road Racer SOLD
95 Cobra - SOLD
cobrassc is offline
cheap, light set of wheels to mount slicks on (Moved From 94/95 Tech) 94whtcobra Wheels and Tires 3 07-19-2002 02:04 AM
How Do I get this off? (Moved from 94/95 Tech) Fordman50 Audio 7 07-18-2002 09:53 AM
Who has taken the front bumper cover off ? (Moved from 94/95 Tech) yellow95 The Body Shop 4 07-12-2002 04:38 PM
Question about fan (Moved from 94/95 Tech) HPLouis Electrical & Wiring 2 07-04-2002 10:48 AM
ANybody that has moved battery to Trunk (thread moved from 94/95 Engine Tech) blackgtstang Electrical & Wiring 4 05-07-2002 11:22 AM
