best battery relocation kit for 1995 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 11-03-2002, 11:04 AM Thread Starter
I am thinking of moving the battery into the trunk of my 95. Thanks, 66kix
66KIX is offline
post #2 of 5 Old 11-03-2002, 01:25 PM
after using a Summit kit in my notch years ago my advise to you is just buy a box and do the rest yourself. none of the kits seem to provide cable conductive enough for proper current and charging. use Welding cable as it contains more strands and is much more conductive. remember you will need a cutoff switch mounted outside the car to run at the track with a trunk mounted battery as well. I will be doing this on my car when it is closer to completion. good luck
Paul
showstopper2 is offline
post #3 of 5 Old 11-04-2002, 12:13 PM
WWS95GT's Avatar
I used 1/0 welding cable on mine and did it that way.The welding cable is plenty big enough and it's very tuff and flexible and heat resistant.W.W.W.
1990 Coupe
''Life's tough......it's even tougher if you're stupid.''
-- John Wayne
WWS95GT is offline
post #4 of 5 Old 11-04-2002, 01:32 PM
P63
Moderator
P63's Avatar
Trader Feedback: (15)
One thing to keep in mind about putting the battery in the trunk. If you have a passenger and get in a crash, that battery could become a missile which will fly throught the seats like they were made of warm butter.
Sturdy metal boxes bolted to the trunk floor are probably much better that plastic boxes held down with straps.
Victor Marshall
Copyright 2019.
P63 is offline
post #5 of 5 Old 11-04-2002, 11:07 PM
Any pics.????
WestCoastMustangs
1994 Black Cobra
SOLD '69 331 Scat Crank, Scat Rods, JE Pistons, Victor Jr's, 230,232-602,602, TFS R intake, 30pd inj, 75 TB, 80ProM, 1 5/8 LT w/ 3in X, Flows, 4.10 12.0 @ 116 @ 2500ft
Silver88gt is offline
Battery Relocation write-up and Kit Anthony93LX50 General Mustang Tech 66 12-23-2014 12:05 PM
For Sale Battery Relocation Alternator Shutdown Relay Kit WV_Snake Electronics and Entertainment 0 11-30-2014 03:05 PM
best battery relocation kit for hatchback fox? slow87GT General Mustang Tech 7 06-04-2014 04:06 AM
For Sale Steeda/Taylor Battery Relocation Kit FS spray175 Electronics and Entertainment 7 01-03-2011 07:38 PM
Summit Battery Box Good--Summit Wiring Kit Bad! LXguy 5.0/5.8 Engine Tech 2 12-04-2001 11:26 PM
