installing a 5'' tachometer w/ shift light - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 11-02-2002, 07:48 PM Thread Starter
ok i took the dash apart, i got the gauge cluster out, i just need to know how to hook up the 4 wires, red, green, white and black, i need to know exactly were these wires need to go
please help
cop88 is offline
post #2 of 4 Old 11-02-2002, 09:06 PM
PMS Tuning Forum Moderator
Redsnk95's Avatar
red=power
black=ground
white= tap into the parking light or headlight fuse
green= goes to the negative side of the coil or you can intercept the lead going to the stock tach.
Troy
Troy
1995 Mustang Cobra
347ci 10.52 @ 127.74 NA-Pump Gas (gone)
New Project in the works.
2009 F150 Lariat *tow truck*
Redsnk95 is offline
post #3 of 4 Old 11-02-2002, 09:09 PM Thread Starter
were are those wires at so i can hook the others up to it
Originally posted by Redsnk95
red=power
black=ground
Troy
cop88 is offline
post #4 of 4 Old 11-03-2002, 09:12 AM
run the red to the fuse box and switched 12v source. The black ground to any ground spot like where the dash harness is grounded. I don't know the wire color for the illumination white wire. for the Tach lead green run it through the firewall harness grommet to the coil wire which is orange and green I believe(dont have the car in front of me to go look at). get yourself a test light and find the negative side of the plug to be safe. you can also use this to find your key on switched 12v source in the fuse box.
Paul
showstopper2 is offline
Shift light wiring question thunderjet302 General Mustang Tech 2 01-31-2015 11:20 PM
For Sale Programmable shift light. 98yellowstangGT Electronics and Entertainment 1 12-08-2014 08:56 PM
For Sale msd led shift light chuxsvt Electronics and Entertainment 1 12-26-2011 02:07 AM
TFS 1 cam shift point, need shift light 87slutstang General Mustang Tech 4 10-13-2011 04:05 PM
What would you rather shift by - tach or light? Ryan87LX 5.0/5.8 Engine Tech 35 04-11-2002 12:34 PM
