ever have to re-ground Oxygen sensors ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 10-30-2002, 05:49 PM Thread Starter
Ever since I've had my code it's thrown intermittent O2 codes, such as lean bank 1/2 and the even better CE code that tells me they actually shut off. (can't remember the exact number) I thought it would just be a bad O2, but two sets later I'm pretty sure this isn't the case. So the fact that they're shutting off completely sometimes is leading me to believe that the ground is really really poor or my eek is going bad.
So I'm thinking about just running a new ground from both harnesses. Has anyone done this before? Obviously before I run the new grounds I'm gonna wanna check with a multimeter, but the idea of being under my car while it's running doesn't thrill me. Some one please help me out with some input/advice. Thanks.
deevoc is offline
post #2 of 2 Old 10-31-2002, 09:13 AM
GDAVENPORT's Avatar
get some gator clips, bare the wires and clip them on. you can play play play with out worrying about 'anonymous' hit and runs.
while its possible that the ground could get corroded, it seems that that wouldnt be the case (sensors are on different circuits) but, its worth a try.
GDAVENPORT is offline
oxygen sensors clubcart84 5.0/5.8 Engine Tech 5 10-15-2013 10:47 PM
Do you ever modify cheap Oxygen sensors or just buy direct fit ones? bigEasy08 General Mustang Tech 5 08-05-2013 07:32 PM
1989 mustang gt randomly shuts off five.zero General Mustang Tech 5 04-10-2013 10:49 PM
oxygen sensors 357gts 94/95 Tech 1 08-14-2002 06:29 PM
