1994 GT electrical woes - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 10-26-2002, 08:37 AM Thread Starter
While trying to fix an intermittent electrical problem with my '94 GT, I've replaced the alt, battery, starter, and negative battery cable. Car periodically stops charging, battery runs down while I'm driving, I find this out when I try to start it, and it won't. Yesterday, when this happened, I had someone turn the key while I looked. The starter ground over slowly, and the small #10 wire attached to the negative battery terminal, going to ground on the body, started to smoke. I cut this wire and left it loose, and the car started right up! I'm having difficulty picturing how cutting a ground wire loose fixed a high-resistance connection. Where does the other end of this wire go? I appreciate any help!
cougar14 is offline
post #2 of 2 Old 10-26-2002, 12:09 PM
ponyboy19's Avatar
that black 10 gauge wire that goes from the neg terminal to the fender then splits off and goes down to the wiring harness needs to be attached.. I know it grounds out the maf and will cause voltage issues with your maf.. I just went through some issues and Pro M was very presistant that i make sure that ground is done correctly when i relocated my battery to the trunk so it must be important.
95 GT
9:1 Dart Block 418w, Vortch YSi, Pa C4 super comp,
92 Gt,
ponyboy19 is offline
Jetsetter's SN95 to 4.6 V8 Swap Guide Jetsetter Member Build-Up Projects 0 04-08-2015 09:43 PM
For Sale 1994 Red Ford Mustang GT Converatible Red mmaci2 Mustangs For Sale/Wanted, 1994-1998 0 07-11-2014 06:27 PM
For Sale 1994 mustang gt pedal assembly Phoenix AZ OCHOHILL Interior Parts 0 03-31-2014 02:23 PM
SOLD 1994 Mustang GT HPDE/Race-ready macher03 Completed Sales 1 10-10-2011 05:49 PM
For Sale 1994 Ford Mustang GT 5.0 H.O satyr36 Mustangs For Sale/Wanted, 1994-1998 2 08-20-2011 11:50 PM
