1995 gt Fog Light Re-wire - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 10-06-2002, 04:18 PM Thread Starter
Question 1995 gt Fog Light Re-wire
I re-wired my fog lights per the article under Tech in Corral. I just want to make sure that I didn't mess up...
I found the red-black wire next to (not across from) the purple-red wire and I switched them.
It works, but I don't want it to eventually cause a short.
Somebody please confirm or correct my actions.
Thanks!
95gt95gt is offline
post #2 of 2 Old 10-10-2002, 03:11 PM
steven506's Avatar
Here's what the article says...
The two wires you will be concerned with are the red/black and blue/red. Use the above procedure to remove these two wires from the harness and switch their positions. These two wires are positioned across from each other and should remain that way, only in opposite positions. The wiring scheme is the same for both 5.0’s and 4.6’s, Cobras and GT’s alike.
I did this simple mod a few months ago, and I distinctly remember a red/black and blue/red wire switch. Also, the wires that I switched were across from one another as indicated in the article.
I'm not sure if maybe you just thought it was purple instead of blue or what. Also, maybe you just misunderstood the meaning of 'across from'. No matter, mine has worked fine for months without any problems at all. I hope this helps you.
steven506 is offline
Want To Buy 87-93 GT Fog Light brackets 1BadAzzWS6 Exterior Parts 3 02-03-2014 08:06 PM
flux welder on engine bay? 95oldyeller The Body Shop 9 10-17-2012 07:35 AM
For Sale Front grill and fog light 2010 GT armymanrn441 Exterior Parts 0 08-22-2012 06:50 PM
Want To Buy 86 gt fog light bar biggie6152 Exterior Parts 3 03-03-2012 02:19 PM
For Sale 87-93 MUSTANG GT FOG LIGHT BRACKET unitedmustangs Exterior Parts 0 03-21-2011 07:05 PM
