voltmeter 1994 1995 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 10-03-2002, 11:21 AM Thread Starter
voltmeter 1994 1995
my 95 cobra's voltmeter keeps dipping down to the lowest point before red. i have replaced the battery, alternator, coil and belt. and it is still dipping. the idle does not drop, but still the meter drops. what else could i check to see could be doing it?
urbanruckus is offline
post #2 of 8 Old 10-03-2002, 06:30 PM
94CobraPace's Avatar
If it is only at idle, then it would be the underdrive pullies. Does it go up when you make the rpms to over 1000 rpms? You could try and put the stock pullies back on and see if that helps. I left off the alt pulley when I installed the underdrive pullies and it only dips when at idle with all the lights on, ac and radio. All I have to do is rev to 1000 rmps and it does back to normal.
2010 Shelby GT500, Kona Blue W silver stripes.
2007 Shelby GT500, Vista Blue with Tungston gray stripes, 1 of 119, Wifes car...
94 Cobra Pace car Convertible # 591
2001 Cobra vert # 2001 SOLD
94CobraPace is offline
post #3 of 8 Old 10-04-2002, 02:22 PM Thread Starter
yep
yea that is exactly my prob & it does go back to normal when i rev up to 1000. so i should take the pullies off & put stock back on?
post #4 of 8 Old 10-05-2002, 08:41 AM
If it is at about 10v when sagging into the low zone, then no, leave the pullies alone.
If it goes all the way over to 8v and rests on the left side back stop, then you may want to put the stock alternator pulley back on (only). It seems like most do that; I do and it never dips lower than 10v.
94GTVert is offline
post #5 of 8 Old 10-06-2002, 11:13 PM Thread Starter
yea
over the weekend i put the stock alternator pulley back on & it helped a lot. now during the day it doesn't really dip at all, but during the night when i have the radio & lights on it still dips, not as much, but still lights dim slightly-WTF? what else could i do? & is this normal? does increasing the timming make any difference?
post #6 of 8 Old 10-07-2002, 08:47 AM
On my 94 Cobra with underdrive pullies, minus the alt pulley, it does the same thing. The only way to fix if is to go back to stock pullies. It should be OK, just don't idle a long time at night with lights, ac and radio on, battery might go dead after 15 minutes +. It is something I have learned to live with, I don't have cooling issues so it does not bother me.
post #7 of 8 Old 10-07-2002, 09:09 AM
How much of a "dip" is acceptable?
My AODE at idle, in gear w/ lights and high speed fan on gets pretty low at times. It never drops all the way to 8, but rides in the lower quadrant of the guage. Once moving it is back up to 14. Is this killing my alternator / battery, or is this acceptable?
[SOLD] Sapphire Blue 1995 GT AODE, 3.27, ASP Crank Pulley, "tmoss" ported lower intake, Magnaflow catted H-pipe, FRPP cat-back, "Jerry mod", PI Stallion 2600 Stall
1965 Nova SS 327
novadude is offline
post #8 of 8 Old 10-07-2002, 09:29 AM
KJ94GT's Avatar
Pulleys are junk, IMO.
94 GT C4 transmission, SVO block'd 331, 160# injectors, 2 fuel pumps, 10pt cage and a big turbo
http://www.dfwmotorsports.net
KJ94GT is offline
1994 - 1995 Cobra Registry Thread wldtang 94/95 Tech 331 11-01-2018 03:31 PM
Want To Buy 1994 or 1995 cobra rochoa21 Mustangs For Sale/Wanted, 1994-1998 0 08-19-2015 01:39 AM
For Sale J4J1 Cobra ECU 1994 - 1995 94redgtvert Electronics and Entertainment 13 07-20-2014 09:50 AM
For Sale 1994 1995 Trick Flow Intake Elbow Adaptor zak Windsor Engine Parts 2 05-20-2012 08:18 PM
1994 and 1995 Mustang - any difference at all? Imyourzero 94/95 Tech 17 05-02-2002 01:38 PM
