Tachometer - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 10-03-2002, 02:50 AM Thread Starter
Tachometer
I have installed a tach in my car and its way off. Its setup for a V8 and all that stuff. The power ground light is hooked up but im not sure where to hook the tach lead to. I have tried 2 tachs and there both off. I called a couple of friends and they are having the same problem. Must be something in the water around here.
Any help would be appreciated.
tiethescore is offline
post #2 of 2 Old 10-03-2002, 11:35 AM
PMS Tuning Forum Moderator
Redsnk95's Avatar
The green wire goes to the negative side of the coil. If your running an aftermarket ignition box, then the green wire goes to the box.
Troy
Troy
1995 Mustang Cobra
347ci 10.52 @ 127.74 NA-Pump Gas (gone)
New Project in the works.
2009 F150 Lariat *tow truck*
Redsnk95 is offline
tachometer fluctuations thunderjet302 5.0/5.8 Engine Tech 8 11-09-2016 03:09 PM
For Sale AutoMeter 2698 Z-Series Tachometer mysvt1 Electronics and Entertainment 0 03-29-2014 09:47 PM
1998 Tachometer with 2004 PCM/Engine Brut225 SVT & DOHC 4 03-18-2014 08:21 PM
For Sale Auto Meter Ultra Lite Pro-Comp 2 tachometer. fireman Electronics and Entertainment 3 06-16-2012 07:11 PM
Want To Buy 8,000 RPM SVO Factory Tachometer stizzytech331 Electronics and Entertainment 0 03-25-2012 09:33 PM
