headlight problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 09-23-2002, 11:50 PM Thread Starter
Guarddog II's Avatar
headlight problem
Did a search on corral...and this explains the problem pretty well...
k, here is the deal. I just got done today doing my 3G 130 amp alt upgrade. I got done, hooked up the voltimeter and it read 14.1 volts with all accessories on. I thought I was sitting pretty, everything was looking good until tonight when it got dark. I was out and I turned my headlights on noticing that the passenger side headlight was dimmer than the the driver side. I then turned on my right turn signal and the green arrow in the car stayed on, and the blinker outside did nothing . Here is the kicker, if I turn the headlights off, then the passenger side blinker blinks like it is suppose to. As far as the driver side goes, I have no issues, the headlight is bright as it is suppose to be, the turn signal blinks even when the headlights are on, nothing wrong at all. It is just the passenger side that is doing it. I swapped the headlight bulbs thinking maybe I had bad bulb but that did nothing, problem still exists. Please Help!!! Thanks!!!
95GT Vert; Do you want a list of whats in my garage or whats actually on my car?
Guarddog II is offline
post #2 of 5 Old 09-24-2002, 12:10 AM
You have a ground wire for each headlamp,this is probably your problem.The ground for the passenger side headlamp is at the corner of the fender and radiator brace.You also have one for the left headlamp in the same location on the drivers side.
chuck943 is offline
post #3 of 5 Old 09-24-2002, 09:56 AM Thread Starter
Thanks!
Chuck
Thanks for the information, will check it out when I get back from work today.
Makes sense as I was digging around looking for an electrical fault somewhere else...must have yanked something loose.
Much appreciated, this kind of information saves a lot of wasted time following wires.
Will let you know how it goes....
post #4 of 5 Old 09-24-2002, 10:01 AM
Sounds like a bad ground to me. I have had lights and blinkers do strange stuff like you described, and the ground has always been the problem.
matt95 is offline
post #5 of 5 Old 09-25-2002, 12:35 PM Thread Starter
Thanks for the info
Loose ground wire. Would never have found it, bolt was just a bit loose so I would have totally overlooked it. Couple twists of the ratchet and all better.
Thanks!
DIY: Headlight Restoration using Clear Coat ProStreetDriver General Mustang Tech 2 07-15-2014 04:43 PM
Replacement headlight adjustment problem Harrythegreek General Mustang Tech 8 02-18-2013 03:33 PM
Help Intermittent problem black 93 lx 5.0/5.8 Engine Tech 1 01-02-2013 10:29 AM
5.0 intermittent cold start problem (long) EL1XR8 5.0/5.8 Engine Tech 4 10-10-2011 01:57 PM
Fuel Delivery Problem Solved!! Blown46Cobra GT & SOHC 9 12-18-2001 01:44 PM
