1994+ v6 ccrm vs. 1995 GT - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 09-22-2002, 04:07 PM Thread Starter
will the ccrm from a 94-95, or 96+ work on a 95 gt?
Thanks,
-Mike
Mikal is offline
post #2 of 5 Old 09-23-2002, 01:32 PM
The V6 CCRM has only 1 fan control relay, this would be low speed fan on a GT, otherwise it's the same.
Have a good one
Jim
twisted5.0 is offline
post #3 of 5 Old 09-24-2002, 02:10 AM
Mikal,
If you have the same problem as everyone else with the CCRM recall ....
It is the fan!
Unplug the wires going to the fan. Are they crumbly, dry, burned?
The CCRM recall involves putting a circuit breaker on the fan wires to prevent the fan from drawing too much power and cooking/burning the wires. Some have underhood fires result.
If you are having fan problems, your CCRM is probably fine.
HTH
94GTVert is offline
post #4 of 5 Old 09-24-2002, 02:36 PM Thread Starter
its my fuel pump..
Mikal is offline
post #5 of 5 Old 10-21-2002, 06:59 AM
yellow95's Avatar
I know this is old, but just so everyone knows. The v-6 ccrm WILL work on the v-8's. The difference is in the fan wiring. The v-6 just doesnt have a pin in the ccrm harness for the high speed fan. I know for sure, cuz I went junk yarding, and brought two v-6 ccrms home. One with the harness, so I could compare. They will work fine.
Gary
Yellow 95 GT vert, Kenne Bell Blowzilla/Flowzilla, Y303 Heads, Water Injection.
I travel all rainy roads, and hydroplane thru life.
yellow95 is offline
For Sale 1994 1995 gt ac compressor Nogoodnamesleft Windsor Engine Parts 0 10-21-2012 10:45 AM
For Sale CCRM - 98 GT, 99 GT, & 00 GT metalman302 Electronics and Entertainment 4 07-13-2012 01:19 PM
For Sale Mustang GT and Cobra parts! 2kBossGT Modular Engine Parts 14 06-30-2012 04:29 PM
Running 275's up front 1995 1994 GT Joker 5.0 Wheels and Tires 19 05-03-2003 04:19 AM
NAturally aspirated 1994 1995 GT 5 speed running 4:10 gears Imyourzero General Mustang Tech 25 09-24-2002 09:36 PM
