CCRM - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 09-09-2002, 05:52 PM Thread Starter
the_shadow's Avatar
CCRM
are they the same on a cobra and a GT??? how much am i looking at if i buy this babby new, how do i test to see if its doing what i need it to do, heres the deal
first off after the car sits you have to cycle the key switch several times for it to start
sometimes when your going down the road it will just die under normal driveing conditions but always almost autmaticley starts back when going down the road but when it dies while stoped it has a hell of a time restarting.
i went buy the local mustang shop and bought a walbro 190 LPH pump 109.25$ includeing tax at blue ovail classics in kingsport Tn. great place to deal with!
2004 competiton orange mach 1, 4.10 gear, pro 5.0
off raod X pipe, slowmasters. 4 sell
the_shadow is offline
post #2 of 11 Old 09-09-2002, 07:56 PM
94svt5.0's Avatar
I dont think the CCRM would be related to your car dying. I think it just controls the high and low speed relays for the fan. They run around 150 bucks. I think the cobra and GT is the same, not really sure though. Do a search on CCRM, there is a guy on here who is wanting to sell a new one he did not need.
1994 cobra # 1067
white ex./black leather int.
-Crane 2031 cam
-Bullit suspension
-BBK off road h-pipe
-basani cat-back
-superchips power chip
-mac cold air induction
-frpp king cobra clutch
-18" konig wheels with nitto 555zr
- 3:73 Ford racing gears
-Ford Racing aluminum driveshaft
-Auburn HD limited slip diff.
- 75 mm bullet MAF
94svt5.0 is offline
post #3 of 11 Old 09-10-2002, 12:15 AM Thread Starter
the_shadow's Avatar
im thinking the fuel pump relay might be kicking out, i know this want be the cause of haveing to cycle the key, but im keeping all options open!
post #4 of 11 Old 09-10-2002, 02:26 PM
The CCRM controls, Fuel Pump, A/C compressor clutch, EEC power and High /Low fan. Based on your problem I would have to say your CCRM is on its way out.
Have a good one
Jim
twisted5.0 is offline
post #5 of 11 Old 09-10-2002, 03:06 PM
Don 95Vert's Avatar
My vote would be a bad TFI module...
95 Lightning - Slow
95 Convertible 357 turbo
10.5/135 @ 3800#
SCT Tuned
Don 95Vert is offline
post #6 of 11 Old 09-10-2002, 03:31 PM
Re: CCRM
You just described the problem ive been having exactly. Same symptoms, i just replaced my distributor two days ago and havent had the problem occur again yet. What is the CCRM module?
Clemens9 is offline
post #7 of 11 Old 09-10-2002, 03:42 PM
My Bad!!! I got this post confused with another one also having fan problems, I just reread the original post and have to add my vote with Don, the TFI or the pickup in the distributor is the likely suspect here.
Have a good one
Jim
post #8 of 11 Old 09-10-2002, 07:40 PM
94svt5.0's Avatar
If you have to cycle switch several times to start, then the valve in the fuel pump is bad. Replace the fuel pump. The bad valve is letting the fuel system drain back to tank after sitting awhile. So, when starting it take it longer to pump back pressure.
1994 cobra # 1067
-Crane 2031 cam
-Bullit suspension
-basani cat-back
- 75 mm bullet MAF
94svt5.0 is offline
post #9 of 11 Old 09-11-2002, 12:49 AM Thread Starter
the_shadow's Avatar
from my experences with TFI problems the vehicles usually wont start back untill it cools off.
had a 94 in the shop the other day when it got hot the car would die and not start back, you could pour water on it and it would fire right up.
post #10 of 11 Old 09-11-2002, 10:41 PM
Hot TFI Modules....
Shouldn't be happening in the SN95's because it should be mounted on pass fenderwell under intake tubing. Ford is in a class action suit regarding TFI modules that were distibutor mounted and the stall problem has been linked to several deaths from the resulting accidents. DO a internet search for TFI and you will find several sites detailing the problems and lawsuit. THere may be others with this problem that are TFI related but aren't covered in the recall/suit beacue the module was moved to a cooler location (used to be distributor mounted).
Tom
My fourth pony:
1999 GT Vert, Vortech V-2, IPSCHASSIS SLA, Griggs GR40 Rear, Bassani/Dynomax, Fikse wheels, roll bar, too much to list...
Tom C is offline
post #11 of 11 Old 09-11-2002, 10:45 PM
TFI Sites...
OK.. I was lazy... let me redeem myself....
http://www.tfisettlement.com/
http://www.wrenchead.ca/HTML%20Prese...der/sld058.htm
http://www.usatoday.com/money/autos/...ion-settle.htm
There are more out there....
Tom
My fourth pony:
Tom C is offline
