problem with 1995 speedometer - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-22-2002, 12:59 AM Thread Starter
Question problem with 1995 speedometer
i have a 95 GT vert and my speedometor turns on and off sounds like a loose wire or something? anyone else have this problem? if so do u have a solution?
CHI95stang is offline
post #2 of 4 Old 08-22-2002, 12:45 PM
Your speedo wire might be off. I don't think it's that hard to fix. Take it to a local garage for a quick fix.
punestang is offline
post #3 of 4 Old 08-22-2002, 01:44 PM
I agree, the speedo wire might be off. I forget the color of it though.
Anaconda-Is-Gay is offline
post #4 of 4 Old 08-22-2002, 03:40 PM
Vehicle Speed Sensor (VSS)
It's located on the tranny... jack it up and run your hands around it looking for the wire leading to it and tighten it up. No biggie! Also clear your computer... it should be holding a code for it showing low voltage signals. Just had long tubes instaalled and the shop forgot to reattatch the VSS and I to do the same thing.
Hope it helps!
Tom
My fourth pony:
1999 GT Vert, Vortech V-2, IPSCHASSIS SLA, Griggs GR40 Rear, Bassani/Dynomax, Fikse wheels, roll bar, too much to list...
Tom C is offline
Help: Steering Problem - 2012 Boss 302 domesticpower Road Racing/Auto X 10 06-23-2014 07:55 PM
1994 / 1995 starting problem P63 94/95 Tech 18 02-11-2002 02:15 PM
1995 COBRA Electrical problem P63 Electrical & Wiring 5 01-14-2002 11:08 AM
major problem with 23-tooth speedometer gear rmquake General Mustang Tech 8 01-13-2002 04:37 PM
Where's speedoMETER cable on 1995 Cobra ? CWCobra General Mustang Tech 2 01-13-2002 12:21 PM
