why is my car not fully charging? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-20-2002, 02:39 PM Thread Starter
i took my underdrive pulley's off today because my car has not been fully charging. it fluctuates often, causing an assortment of problems. i thought putting the stock pulleys back on it would fix it, but not the case. my alternator is not a month old yet. so i feel like it is ok. what else could cause it not to fully charge? thanks,
chris
94 GT TFS Track Heat Intake, Twisted Wedge Heads, FTI Cam, 65mm TB, C&L 73mm MAF, 24# Injectors, Kirban AFPR, 255lph, BBK Longtubes, Off Road H-Pipe, BBK Underdrive Pulleys, Mac CAI, Pro 5.0 Shifter w/ tri-ax handle, Eibach springs, 3:73's, SPEC Clutch, JMS Chip. KB Subframe Connectors.
Best [email protected] 320rwhp 320rwtq
white94 is offline
post #2 of 3 Old 08-20-2002, 03:07 PM
a97ace's Avatar
Go have the altenator and the battery checked out, just to make sure that they are ok. New doesn't always mean ok, unfortunately
1995 GT coupe/ (converting from 306ci to 347ci) 70tb,75 MAF........ you know the rest of the story.
2005 Mitsubishi Lancer Evolution (4 doors, 3 diamonds, 2 litres, 1 turbo = 380 awhp)
1989 GT (Building another stroker)
a97ace is offline
post #3 of 3 Old 08-20-2002, 05:45 PM
Get the car up to operating temp. Get a volt meter and put it on Volts DC, then see what the battery terminal voltage is while idling. It should be about 14-15vdc. If it's less then it could be a bad voltage regulator. I'm going through this right now.
94Goezquik is offline
