anyone know where the fuel pump relay is? (Moved from 94/95 Tech) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 08-07-2002, 03:53 PM Thread Starter
im trying to fix a friend of mines car. i pulled codes and i got fuel pump relay low volts.. i cant find it anywhere... it doesnt show it in my chiltons or in the fuse boxes...any help would be great!
95 green gt D.S.S. 347 stroker and a 150 shot. [email protected]
ron 95gt is offline
post #2 of 13 Old 08-07-2002, 05:08 PM
oldpaint's Avatar
In a FOX it's under the drivers seat, you might try looking there.
oldpaint is offline
post #3 of 13 Old 08-08-2002, 01:48 AM Thread Starter
thanks i will check there... anyone else know for sure where it is on a sn-95?
ron 95gt is offline
post #4 of 13 Old 08-08-2002, 03:51 PM Thread Starter
somebody has to know.....
ron 95gt is offline
post #5 of 13 Old 08-08-2002, 04:05 PM
Anaconda's Avatar
Look by the wires by the driver's side taillight. That *might* be the relay. There is a plug you can disconnect to shut off the fuel pump.
Anaconda is offline
post #6 of 13 Old 08-08-2002, 06:07 PM
94svt5.0's Avatar
I pulled that same code on mine. Never could find the relay. The car kept dying at stops. I ended up fixing it by unplugging the battery and letting the computer reset. It never has had another problem and that was 10k miles ago.
1994 cobra # 1067
white ex./black leather int.
-Crane 2031 cam
-Bullit suspension
-BBK off road h-pipe
-basani cat-back
-superchips power chip
-mac cold air induction
-frpp king cobra clutch
-18" konig wheels with nitto 555zr
- 3:73 Ford racing gears
-Ford Racing aluminum driveshaft
-Auburn HD limited slip diff.
- 75 mm bullet MAF
94svt5.0 is offline
post #7 of 13 Old 08-09-2002, 12:50 PM
The fuel pump relay is in the CCRM mounted in front of the Coolant Recovery bottle on SN-95s, this module controls low/High cooling fan, AC compressor and Fuel Pump.
Have a good one
Jim
twisted5.0 is offline
post #8 of 13 Old 08-09-2002, 01:23 PM Thread Starter
twisted5.0- is it inside that ccrm does it come apart?? or is it that whole unit that needs to be replaced? i will go investigate it some more on the car. thanks
ron 95gt is offline
post #9 of 13 Old 08-11-2002, 01:25 PM
Art Zarate Jr.'s Avatar
Replace it
The hole unit has to be replaced. Are you sure it is bad? Find a wiring diagram and probe the wires for 5 seconds of voltage at key on.
93 Cobra - rebuild in the works
ASE master, Ford Master certified technician, I specialize in all electrical, driveability, engine performance, custom stereo designs, and getting my customer complete satisfaction with their build.
Art Zarate Jr. is offline
post #10 of 13 Old 10-09-2002, 09:12 PM
Did anyone ever find out if the whole CCRM has to be replaced if the fuel pump relay goes bad? The genious at the local parts store seems to think that the "fuel pump relay" he gave me somehow goes into the CCRM but I see no way to open it without breaking it
I found it funny that the 1995 Ford Mustang shop manual by Ford says the FPR is in the Power Distribution Center when in fact it is in the CCRM
macin95five0 is offline
post #11 of 13 Old 10-09-2002, 09:18 PM
Eric 94 Cobra Coupe's Avatar
I don't think it's repairable. Someone could make some good money throwing together off the shelf relays to replace the CCRM with a repairable/upgradable unit.
2003 Cobra Coupe
Dark Shadow Grey
"Ever seen how fast a horse runs after it's been bitten by a snake?"
362 RWHP/355 RWTQ SAE corrected. 1000 miles, stock w/o silencer.
401 RWHP/370 RWTQ SAE corrected. 3800 miles, Steeda CAI, Borla Stinger.
Eric 94 Cobra Coupe is offline
post #12 of 13 Old 10-09-2002, 09:56 PM
I looked in the 95 shop manual and in the electrical schematics it shows it in the CCRM.Any vehicle from ford with a ccrm has all of these relays(EEC,Fuel Pump,Cooling fans)in there. This is a sealed unit and has to be replaced,but I guess if you were ingenious enough you could find a way inside it and replace the relay but it was not intented for you to do so.
chuck943 is offline
post #13 of 13 Old 10-10-2002, 02:05 AM
I know it does show it in there, but you would have to know it was in the CCRM to think to look at that diagram. Look around at the other parts where it says stuff about the fuel pump relay and one part says it's in the power distribution center, I believe it says that about the FPR in the v6, but I'm pretty sure it never tells you a location for the v8 FPR, I just assumed it was the same.
Aeru 16307 fuel pump 10Ga wiring kit ndmus88gteng General Mustang Tech 3 02-19-2016 10:56 AM
Fuel Pump Tech CobraR77 94/95 Tech 3 02-16-2013 02:32 PM
Fuel pump relay issues (93 5.0L) superman22x General Mustang Tech 10 05-01-2012 07:23 PM
94 stang fuel pump relay not getting power rdub91683 94/95 Tech 2 02-06-2012 01:15 PM
car drops fuel presure at 5800rpm, need help 98muscrat Superchargers 44 06-15-2011 11:22 AM
