Anybody with electrical experience (Moved from 94/95 Tech) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-01-2002, 08:06 AM Thread Starter
yellow95's Avatar
I am wireing up a on/off switch for my water injection pump. Can I wire the hot side directly to the battery (fused), and run the negative side to the switch in the car? Anything wrong with that?
Let em know.
Gary
Yellow 95 GT vert, Kenne Bell Blowzilla/Flowzilla, Y303 Heads, Water Injection.
I travel all rainy roads, and hydroplane thru life.
yellow95 is offline
post #2 of 3 Old 08-01-2002, 10:56 AM
INTP's Avatar
If I understand you correctly, I'd think you wouldn't want to do this.
The car's electrical system is negative ground, which basically means that you feed the positive lead with voltage (switched or otherwise) and the return path is the ground. From what I understand of your question, you want to connect the negative to the switched (positive) lead, not what I'd recommend.
The simplest solution is to run the positive to the switched circuit and the negative to a nearby ground.
If the current draw of the pump is high, then you'll want to use a relay. The ignition switched circuit will trigger the relay, and you can feed the pump with battery current (with a fuse). This is basically what the starter does, with the starter solenoid being the relay.
Either way, you should put a manual switch between the switched circuit and the relay/pump.
INTP is offline
post #3 of 3 Old 08-02-2002, 02:04 AM
I agree with INTP. You should use a positive ignition switched source. Your idea sounds like the way interior lights are wired; not good for ANYTHING engine related (except the underhood light
95 Cobra original owner
FMS extender, BBk headers, Bassani X-pipe, Flowmaster catback, FMS C springs, Hurst shifter, KN, CAI, 190 lph, 3.73 gears, 3220 lbs w/o me, 97k miles
95svt is offline
Home Electrical Question Paully's5.0 Lounge 0 12-28-2013 05:36 PM
No air out of center vents - help replacing vacuum canister (thread moved from 94/95 Tech) BLK90LX General Mustang Tech 0 06-24-2002 12:43 AM
Fuel/Tming curves-Computer question? (thread moved from 94/95 Engine Tech) poostang EEC Tech 12 05-12-2002 09:52 PM
ANybody that has moved battery to Trunk (thread moved from 94/95 Engine Tech) blackgtstang Electrical & Wiring 4 05-07-2002 11:22 AM
Anyone runing turbos? How much PSI are you running? (Thread moved from 94/95 Tech) 2Slow4You Turbochargers 15 04-08-2002 04:31 PM
