*Fox guys: Add this to your knowledge pool - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 06-16-2012, 12:23 PM Thread Starter
I'm a Fox Body expert 'cuz I say so.
TWISTED89GT's Avatar
Maybe this is old news but I've had foxbodys for 15 years and this was a first.
I had an intermittent issue with the blower motor and blinkers not working on my 92 LX. Taking the logical route I assumed fuses, switches in the HVAC system etc. The actual issue was the ignition switch. I defies logic, but it seems when the ignition switch starts going out it will cause these types of maddening issues.
To test this theory if you are having this same issue turn your key back or forward until you feel slight resistance then try the blinkers or blower motor.
Obviously this isn't a fix all as so many other issues could be causing it the blower motor or blinkers not to work, however this is a fix for one of the electrical issues that sends people on parts buying binges that don't solve the problem.
TWISTED89GT is offline
post #2 of 8 Old 06-16-2012, 01:49 PM Thread Starter
Just finished removing the old switch. Literally fell apart when I removed the column cover. Give these a check people's they have burned many cars, and or ruined the wiring harness.
post #3 of 8 Old 06-16-2012, 02:14 PM
such an easy cheap fix. I finally realized mine was bad when the car wouldn't satay running once i released the key. Was 30 minutes from home, i had to position the key to where the fuel pump etc would run and jump across the solenoid. Nothing like driving down the road and having your car keep driving, while your try to re position the key to the exact spot to make it run again once i took the cover off the switch just fell -apart.
orvil01 is offline
post #4 of 8 Old 06-17-2012, 10:45 AM
Zip tie that thing up tight to the column, even if you just replaced it.
Megasquirt
seijirou is offline
post #5 of 8 Old 06-17-2012, 11:05 AM Thread Starter
Always good insurance.
post #6 of 8 Old 06-17-2012, 11:35 AM
Trader Feedback: (40)
i swapped an '87 steering column into my '92 a while back, and swapped the '92 stalk in place of the '87 one (wipers, turn signals, and high beams). I had read that the '87 stalk is different and would require some rewiring to work with the newer wiring, but was under the impression that if I used my '92 stalk, everything would basically be the same as if it had the newer column still in it and no rewiring would be necessary. Well I finally got around to plugging everything in, and my turn signals dont work, but my hi-beams and wipers work.
I'm using the ignition switch from the '87, and maybe its bad and could be my problem. I will report back
notchthis is offline
post #7 of 8 Old 09-09-2012, 12:02 PM
snake187's Avatar
Definitely added!!!,,I've been throwing money and parts at my 91 ssp like a mad man to figure out why my AC cut out at the same times my blinkers did intermittently and this was golden info to me and fixed the issue completely,thank you sir,would have never thought of this switch
snake187 is offline
post #8 of 8 Old 09-15-2012, 04:27 PM
fox88's Avatar
Very common problem. All the older Fords from back in those days has Ign. switch issues. Its generally the first thing you should check, actually.
fox88 is offline
NEW: Track Guys at the BRAND NEW Atlanta Motorsports Park, June 30 - July 1 Stanger58 Midwest 0 06-03-2012 02:30 AM
NEW: Track Guys at the BRAND NEW Atlanta Motorsports Park, June 30 - July 1 Stanger58 Southeast 0 06-03-2012 02:29 AM
NEW: Track Guys at the BRAND NEW Atlanta Motorsports Park, June 30 - July 1 Stanger58 Mid-Atlantic 0 06-03-2012 02:29 AM
NEW: Track Guys at the BRAND NEW Atlanta Motorsports Park, June 30 - July 1 Stanger58 Road Racing/Auto X 0 06-03-2012 02:20 AM
Hey guys 1986stangfan Lounge 1 05-23-2012 10:23 AM
