Tach signal problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 06-15-2012, 12:05 AM Thread Starter
Tach signal problem
# #14
apaulk86
I'm having a tach signal problem on my 96 gt. My stock tach worked fine for a long time and then it would randomly go out on me and after that happened, it would only work when it rained. Since that happened in assuming that there is a loose ground under the hood somewhere. Anyone have and ideas for me??? I now have an aftermarket I hooked up but no good tach signal. And also, how do I test the wire near the ECM?
apaulk86 is offline
post #2 of 5 Old 06-15-2012, 06:34 AM
wmburns's Avatar
I would start by confirming ground G203 on cluster pin 7 (BK/W) and ground G103 on cluster pin 9 (BK/Y). Measure back to battery negative. The Ohm reading should be very low.
Ground G203 is located behind the center console. G203 is also shared with many devices including the radio. It's frequently messed up during a radio install.
Next inspect the PCM area and connector for evidence of water or rodent damage.
wmburns is offline
post #3 of 5 Old 06-16-2012, 05:04 AM Thread Starter
I just read this, and I plan to do the checking later this morning. Something strange happened tonight on my way home from work that hasn't happened in a few months. I took a right hand turn into my neighborhood and saw the tach needle go up for about a second and a half and then shot back down to zero.
Until I check out those grounds tomorrow, I have no clue what the hell to think. This car has a mind of it's own, period. But, if the grounds turn out to be good, then the only other thing left is the tach signal wire coming from the ECM right? The reason I say that is because I have an SCT Livewire tuner and it reads the rpms just fine through the OBD port.
apaulk86 is offline
post #4 of 5 Old 06-17-2012, 09:45 AM
wmburns's Avatar
Congratulations! You get a gold start for using your grey matter! Yes for the 96-04 MY, the tach signal comes from the PCM. So if the PCM has the correct RPM's, then the problem is in the cluster or wiring.
The tach signal is cluster pin #8 (wire color T/Y).
For the 96-04 MY Mustang, the usual method to get an aftermarket tach is to use a tach adapter. Examples include the Autometer 9117. The tach adapter is necessary due to the way the NDIS ignition works.
Here are some examples:
http://www.autometer.com/productPDF/0561B.pdf
wmburns is offline
post #5 of 5 Old 06-22-2012, 04:17 PM Thread Starter
Auto Meter 9117 Tach Adapter Install - YouTube
Thanks for the tip but I was able to tap into that wire without spending another 78 dollars on an adapter. The tan yellow wire was just slightly broken at the plug
apaulk86 is offline
Stock tach problem ajdiebo Electrical & Wiring 3 05-06-2012 11:10 AM
Random misfire problem? chargedWS6 5.0/5.8 Engine Tech 4 04-16-2012 04:39 AM
Opinions on breaking up problem mw95gt Turbochargers 18 06-13-2011 12:40 PM
starting problem 94whtlite#2669 General Mustang Tech 1 06-12-2011 10:25 PM
Four Cylinder Ignition Problem lmacklem 5.0/5.8 Engine Tech 3 12-17-2001 03:00 PM
